Joined: 22/12/2015 Posts: 246 Points: 776 Location: Birmingham, AL, USA
Summary:
For me this was just such a pleasure to pursue. It is a kit which can be just as hard and challenging as you want it to be. It is NOT a simple build and many work arounds are to be discovered. Mechanical knowledge is very helpful. Overall the quality is close to excellent. The chrome plating is durable and the best i have seen. There are fragile parts which may be left to the end to install. You will see that in my build entries. I was the demon of my own curses on this one, as the decision was made to go full bore for accuracy rather than bells and whistles. A lot of trial and error, rebuilds and searching for material sources. Most apparent is the color of the engine and transmission castings; they are NOT silver but cast iron. A good steel color worked best for me and dirty it up a bit for oil and grime.
Most things fit, some don't. Trust the pictures over the description of the step. Watch peg sizes, usually there is a large and small, very easy to screw up. The pictures show this, words don't mention it! Learn the difference between bolts and screws, coarse and fine thread. They strip easily. Use the little bags for spare parts and mark them per part. You will have a lot left over but that is good as they will probably be needed.
I was blessed with an Easy Rider replica to go see and photo. Many pictures are posted for reference. This replica was a bit different from the kit's source machine. There is no original left but there are some excellent replicas out there.
I had 450 hours of fun.
You’ve summed it up perfectly, and what an excellent build you have done. Patience is a virtue with this build and you’ve pulled it of beautifully. Very well done. Mark Regards Markwarren (Mark) Admin
A small follow up on my Easy Rider. I managed to buy a FatBoy helmet out of Hong Kong thanks to MWB's help. Now it has to be painted and decorated and I believe Mark Warren did one. Mark can you tell me what paints and colors you used. The photos look like the paint is an silver undercoat with a translucent top coat. Sort of candy color as on model cars. How did you do your stars? Decals? And how many did you use. Hard to tell from the movie photos. All in all, very happy, took a while, not cheap on the after market but it makes the project. Tom tnequette attached the following image(s):
Hi Tom The colours were Aston Martin colours Intense blue Frozen white Hyper red Glass effect A friend of mine used to work there and got the colours I needed after I gave him the fuel tank as a reference. As for painting, first mask off the rim and inside and spray white. The stars were cut using a star cutter, you can get these from various stationary stores, and cut out on some decent masking tape. I then place around 17 of these over the top of the helmet and masked the bottom part off. Then apply the red paint to the top. Finally mask the top section off and make the stripes to the bottom and paint blue. I finally sprayed the whole helmet with a sparkle effect varnish. Sound easy, but it took many weeks to do and on one occasion had to start again when my spray gun took to a turn for the worse. Good luck Mark Regards Markwarren (Mark) Admin
Thanks Mark, This looks like a big hill to climb. Will give it a shot and if it doesn't work, "Canary Yellow".
The final postscript. The helmet is done. As Mark warned me, not an easy chore. Paint colors is the best i could do. matching his paint numbers for Aston Martin is not easy But with some understanding folks at a large auto parts store and internet Duplicolor info, we came out OK. So, here is my true end effort. tnequette attached the following image(s):
Superb result Tom.The helmet looks fantastic
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,192 Points: 15,725 Location: ipswich
A superb result. If it weren't for the table setting it looks utterly real.
Thank you for for the kind comments. It was a challenge as well as a lot of fun.
Joined: 22/02/2014 Posts: 201 Points: 589 Location: Big T
Fantastic job Tom. The helmet really makes it complete. Display it proudly.
Well done that man.  That looks excellent, you must be very pleased with that. Looks superb on the bike. Mark Regards Markwarren (Mark) Admin
Thanks for all said. The helmet is the kiss, the iconic element of the movie, cycle and the age. I know. And now ,for me, the whole image represents letting it all go, you handle things, l’m outtta here. That helmet should be part of that kit. Thanks for all the help in finding it and finishing it to match and seal the deal.
Tom That looks fantastic. I know you had a few challenges with the build but what a lovely looking model you have ended up with. Its nice to put a face to the name as well. My builds are all coming to an end (2 on the fat boy, 4 on the lambo) and i would love to do another bike model. I am very tempted by this one i must admit. Are you planning anything new Tom? Tony Happy Modelling
Tony, Lots of good pictures and information on the ER. Building the engine was the best for me. marks tips on filthy dirt was fun. It is NOT silver! The helmet came out of Hong Kong based on a tip from Wyatt from Texas. Cost and postage was about equal and the paints were not in your normal kit. But when you spend a Grand for the bike what's another hundred. The Helmet is a must for this bike to give it a 1960's meaning. What's next? Good question. My grandson is on my ass for my RVN helicopter, the CH-46D. Have started one at least 6 times but always had a block. Want do to it perfect which we both know is impossible. Have more than enough data and pictures. Want a full interior. So the Academy 1/48 CH-46D is under way but did not plan on making it a MS build. Maybe i should. Lots of interesting personal history here. The box art on the model depicts a machine I actually flew. Not very well however, as in Oct 68 , I was copilot to a major to was leading a strike mission of four. We were shot out of the zone and auto-rotated to a valley floor 1500 feet below. Pilot did a great job, all got out and picked up after a bit of 'conversation' with the other side. The 46 burned up. Strange, have never said some of this before but it is a great helicopter, so we shall try. tnequette attached the following image(s):
Tom Thanks for the update. That kit looks like something a bit special and listening to your experiences there would have a real meaning for you. Kind regards Tony Happy Modelling
