Hi All, Well the dragster (not the body shell) is as complete as it can be till I sort the assembly of the motor to drive the back axle. For now I have attached the first pic which is the dragster with the rear wheels in place but not connected (front wheels connected). Pic 2 (attached) is the smoke generator that arrived this morning. (Some adaptation required for full operation). Bits on order and due to arrive very soon (delivery services pending) are as follows: DC motor in a mount with a geared axle. Heavy duty nylon axle bearers. A driver figure that will be converted into the required Fireman. The second vehicle (Top Fuel Dragster). Working on and getting some positive results are: Power supplies. Female figures Pit crew - working the start line, so will need to be adapted. Therefore more to follow soon. Happy building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,866 Points: 20,915 Location: Northamptonshire, England
Nice work Derek  Putting a lot into this, going to look great. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Nice work Derek  Putting a lot into this, going to look great. Mark Hi Mark, Thanks for looking in. I`m putting a lot into this dio, but it would be the same whether the "Smokin" bit works or not as I want to create a full blown dio of the start line for a drag strip. Still have a few undisclosed ideas of what could be added. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks for looking in Kev and as always I appreciate your input. Many Thanks Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, The first of a few awaited deliveries arrived this morning. This is the figure that is intended to be a 1960`s racing driver in 1:24 scale. I have started his transformation already, so he`s been under the knife. First I removed the lapels from his open drivers suit (not good for a fireman to have an opening in his protective suit), then removed the peak from his crash helmet. Finally for today on this part of the project I formed up the basic shape of his fireman's head gear with some milliput having attached his head. Hopefully tomorrow I can refine that work and crack on with working how his hands will be fixed when I`ve scratch built his fire fighting equipment. Three pics attached: 1: The kit as supplied (Driver) 2: The modified head gear 3: As it is now (Fireman) Hopefully more deliveries tomorrow. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi all coming together very nicely ,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Plastic surgeon now, no end to your talent.  Nice work, looking good. Mark Regards Markwarren (Mark) Admin
Thanks for those who looked in and the comments above. @ Mark: I never thought about a career as a plastic surgeon, but as I still have eight fingers and two thumbs and I`m not leaking any blood  then anything is possible. So who`s first ?? I`m a trained first-aider HONEST!!! Next update soon. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi all, Well today`s delivery was the second vehicle, the rear engine Pro-Fuel class dragster. The first pic is the box artwork, but the colour is bright Red and not the orange colour as it shows (pic from the seller of the kit) I`ll try and get a better one later. I`ve made a small start on this part of the build with the main engine section, constructed, primed and painted the base aluminium colour. Hoping the rest of the hardware ordered will be here by the end of the week. More asap. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Good day for deliveries today. Firstly the updated pic of the artwork of the Pro-Fuel Dragster, it now looks Red rather than the burnt Orange of the previous pic. Then two pics of today`s deliveries: Pic 2: A 6 volt dc power supply for the motor to run the rear axle, plus socket and switch. (I bought two sockets and switches and already have a 12v dc supply for the smoke generator) Pic 3: The 3 or 6v dc geared motor and axle supports (if needed). Latest work update: Pic 4 : Done a bit more to the Pro-Fuel engine, with more detailing to come soon. Until then, keep safe and happy modelling. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Today`s update. Have added some detail to the front face of the Pro-Fuel engine. (Pic 1) Primed loads of parts for the second vehicle (Pro-Fuel, no pics) Then turned my attention to the fireman figure. Painted his suit, made his mask with some acetate and made the fixing points with two cut off brass pin heads. (Pic 2 and 3) Also working on the way to mount the motor and rear axle, but more on that later. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Wow nice work Derek  love the fire marshal Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:Wow nice work Derek  love the fire marshal Regards Phil Hi Phil, Many thanks for looking in and your comments. I am pleased with the way the fire marshal turned out (so far). The guy who sold the figure to me was impressed at the rough change shown earlier and he said it reminded him of his days in the forces as a crashed plane recovery operator. That`s more than praise enough for me. Will be interesting how his fire fighting equipment turns out, as that will be a total scratch build job and that`s not something I`m used to doing. We`ll see when it happens. Thanks again. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Have made some good progress on the Pro-Fuel Dragster today. Pic 1: Shows the frame front end, with the electrics box at the sharp end, followed by the Front axle and steering rack, then the fuel tank behind that. The steering control rod passes through a gap in the fuel tank, with the fuel lines going along the floor of the frame. Pic 2: Shows the rear of the frame with the cockpit controls and the fuel lines at the rear. Pic 3: This shows the completed engine and shows where the fuel pumps will attach to the fuel lines. There are two large frame extensions to fit that will hold the engine and rear axle at a later stage. That`s it for today. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Very nice work Derek, just catching up on the build.  Very nice work on the fireman and the engine, and that motor mount looks good. Looking forward to your next instalment. Mark Regards Markwarren (Mark) Admin
Thanks for those looking in and Mark for your comments. I made a start on the electrics/mechanics of this today.  First thing was to make a temporary test bed to see how things planned out. Now that was the easy bit. The shaft of the motor is 3mm diameter and I want to secure the wheels with micro nuts when I thread the drive shaft, only issue was that the tap and die set I have only goes up to 2.5mm  . Now ordered an extension set which will cover a lot more sizes and not much more expensive than buying one die with the larger size handle. For the picture attached of the test jig, I rested the wheel on the axle with the intention of seeing how the smoke went round the wheel (with it stationary). Note: The motor will be mounted in a vertical orientation on the actual dio to save space under the car. So connected the smoke generator to a lower voltage output than prescribed to give minimal smoke output and it all looked good. THEN 20 seconds later a big pop and a flash and the smoke element was no more. Back to the suppliers on Tuesday to see what can be done. In the meantime I`ll continue with the rest of the build. More to come soon. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi all, Well I`ve contacted the seller of the smoke unit and am awaiting their response. So I thought in the mean time I`d get the fireman finished. Must have been something clicked in my head about a fire. Fire cylinder was made from wooden dowel and the trolley from heavy gauge wire. The gauge at top of cylinder was a jewellery bead fixing pin, with the trolley prop and extinguisher nozzle from milliput putty. Finally made the hose from a length of heat shrink that had a length of wire in it to stop it kinking. Picture has been attached below, showing him ready for action. Hope to have the smoke generator unit issue sorted by the end of the week. Stay safe. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work Derek, that fire cylinder looks great. Shame he didn’t have that at the ready a few days ago. Glad you’ve got the smoke generator sorted. Mark Regards Markwarren (Mark) Admin
A nice bit of scratchbuilding with the fireman and his equipment. You have to be happy with that Derek especially as I think you said earlier in the build that scratchbuilding was out of your normal comfort zone?
Well done, looking good.
Kev.Per Ardua Ad Astra
