10 mm eyebts Options
Nib
#1 Posted : 15 August 2020 09:34:26
Hi could someone give me the measurements of the 10 mm eyebolts internal hole and outer I didn't get them with my issue I am on issue 113 part 24 it said to use 10 mm eyebolts but I didn't receive any can you use 7 mm eyebolts will it work thanks
admin
#2 Posted : 15 August 2020 14:24:50
Give CS a call. They will replace any missing or damaged parts.
Nib
#3 Posted : 15 August 2020 14:59:05
Thanks for reply Mark who is cs thanks
#4 Posted : 15 August 2020 17:56:55
Hi Nib, using 7mm eyebolts shouldn't cause you any problems, just ensure they are securely glued into position.
Nib
#5 Posted : 16 August 2020 08:32:11
Thanks gandale
This page was generated in 0.084 seconds.
