Yamato Deck Assembly Options
Glennard
#1 Posted : 04 August 2020 17:56:12
Rank: Amateur Level 1
I have been looking at the instructions for planking and fitting the decks. I am more tempted to ignore the suggested method and simply install the decks, as the joins are across the bulkheads so they can be pinned as the glue cures. The planking can then be added later on with the decks in situ. I would welcome any thoughts on this.
I have attached a picture of the deck parts dry fitted.
Webp.net-resizeimage (2).jpg (351kb) downloaded 52 time(s).
Current WIP: IJN Yamato
Completed builds: Scottish Maid, HMS Victory (Caldercraft) & HM Sloop Brig Speedy (Vanguard Models)
Web: https://modelshipworld.c...-model-space-1250-scale/
#2 Posted : 04 August 2020 18:26:05
Hi Glennard, BigGrin
You may find the answers you seek if you take a look at the official build for this kit along with the instructions.
Official builds do not just follow the instructions, there are also hints and tips on how to make things easier or they explain things in a simpler way.
Hope this helps.BigGrin
This page was generated in 0.110 seconds.
