10 Pages <1234>»
Magpie1832's 1/350 Revell Tirpitz (Platinum Ed) Options
#21 Posted : 23 July 2020 07:46:58
Excellent work with what looks like some tricky etch, especially inside the funnel.
Cool Cool Cool
Well done
goddo
#22 Posted : 23 July 2020 11:09:24
Doing a really nice job on some very intricate detailing. Brilliant.
#23 Posted : 23 July 2020 21:50:06
Very nice work Chris! It will be a stunner!Love
#24 Posted : 23 July 2020 23:47:46
Excellent work on the funnel area.Love Drool
#25 Posted : 26 July 2020 09:11:44
Thanks for looking in Guys and your nice comments.
Things are slow at the moments as figuring out the best way to build her and which order to fit parts before or after painting and before or after wooden decks etc.
I bought the Top drawings Tirpitz book and that gives me so much info. I will try to correct what I think will be noticed plus a few others just for the sake of it lol.
 The portholes were mainly correct but had to remove four and add about ten in the correct places.
I changed the plastic gun tub and changed it to a strip of old PE fret.
I have joined the two decks together and sanded and then decided to add the cabling along the structure.
Air vents have been replaced and tried to recreate and position them from the plans.
I also notice that some of the solid railings were too short so extended them with Styrene.
I have added the cutouts for the Periscope too.
#26 Posted : 26 July 2020 12:13:08
Superb scratch building ChrisDrool Drool awesome jobBigGrin
Regards PhilCool
#27 Posted : 27 July 2020 16:02:06
WOW Chris, no one can fault your attention to detail!
Most people probably wouldn't have picked up on half of what you have corrected. But it's all the better for it ThumpUp
#28 Posted : 01 August 2020 23:17:50
Cheers guys for the nice comments. Yeah some of the detail I probably could have left but once you start it just goes up.
Firstly started by splitting another component in half to aid in fitting and painting. I thinned out the walls on it as you can see one done in the picture and the other side not. I then modified the other section of it fitted it then put in a wall that should be there and the supports. I then made a couple of vents and then added the wiring and some light fittings(little white blocks on the walls). Also in various places I have put replacement boxes (see by the white styrene).
Now I have started added the MK1 portholes. I have some WEM ones but are not as goo so will use the for the Portholes with no Cover. I've ordered some more MK1's as there isn't enough in one set.
Thanks Chris
#29 Posted : 02 August 2020 12:35:00
Nice work ChrisBigGrin the brass really makes the differenceDrool Drool
Regards PhilCool
#30 Posted : 07 August 2020 16:36:48
Lovely build Chris!BigGrin
#31 Posted : 09 August 2020 09:03:35
Very nice work Chris, loving all the extra detail.Love Love
#32 Posted : 11 August 2020 23:23:55
Thanks guys for the nice comments.
I have nearly done one side of this module, I've added all the portholes some more doors and some extra detail not included. I've added some of the boat racking as well. The instructions show three on this side but the plans only have two so two it is.
#33 Posted : 12 August 2020 07:04:00
Loving the detail you are putting into this. Love Love
#34 Posted : 12 August 2020 23:11:46
Thanks for looking in Mark and your nice comment.
Here is todays update. I have done one side of the Boat rack, walk ways and ladders.
#35 Posted : 14 August 2020 22:24:07
Hi,BigGrin BigGrin
That is some excellent etch.Cool Cool
It will make this into an exceptional build.
Hope you have a good optician.LOL LOL
#36 Posted : 24 August 2020 23:26:28
Thanks Derek for the nice comment.
Here is the slow update. I have now done the other side with the portholes, doors, lights, boat racks and also the decks are added and masked up. I have also added some railings to the front. I will most probably add more railings before spraying.
goddo
#37 Posted : 25 August 2020 06:00:49
A lovely build, Magpie.
Keep the updates coming.
#38 Posted : 25 August 2020 17:14:51
That is certainly looking very nice.Love Love
#39 Posted : 26 August 2020 23:21:33
Thanks guys for looking in and nice comments 😊
#40 Posted : 01 September 2020 22:53:01
Hi guys,
Quick update, I have now fitted the walk ways and most of the railings. This Mini section is now complete so on to a new section.
10 Pages <1234>»
This page was generated in 0.233 seconds.
