Extended DeLorean mit Mods by Andreas Options
Andreas
#1 Posted : 20 July 2020 15:06:51
Groups: registriert
Sorry guys
that I am not so often in the forum at the moment, but at the moment I have to steal my timeBigGrin . Hope it would go better soon.
This is a project of mine that I have been building for 2.5 years now.
The project is usually completed with the plutonium case from issue 130.
For the plutonium case, I lit the plutonium containers with LEDs.
Now there is an extension with 29 issues. As example Wheels for the railroad tracks, railroad tracks and a replacement circuit box "the big chip". In any case, I have ordered these 29 issues. Now waiting for these issues gives me the time I need to "rebuild" the Delorean. Take everything apart again until down to issue 74. The reason is that there are now so many electrical modifications for the Delorean that I want to install. Modified "Flux", "Christmas tree" etc. I would like to incorporate everything. as close as possible to his “big brother”. The complete functions will later be controlled by a remote control, opening the eternal doors and pressing the switches is no longer necessary anymore. Secured under his showcase, everything would be controlled from outside.
I no have already received some of the special editions. A sleeper, a track, sleeper holder. The track is made of solid cast iron, and looks very good. I don't like the sleeper, which is simply brown. No wood grain just not natural.To change to natural, Watertransferprinting is used again for this. There are transfer foils with a wood look. With this I will also treat the other 7 railway sleepers. Further the nuts are imitated on the track and sleeper holders. Here I removed the nuts with a cutter, drilled holes and took real screws with nuts. Now while waiting for the next sleepers i will start taking apart the Delorean.
Forum Support Team
#2 Posted : 20 July 2020 16:10:56
Impressive stuff, Andreas ThumpUp You're right, it looks much better with the sleepers water-transferred - much more realism.
Gray
#3 Posted : 20 July 2020 16:17:09
stunning job.
Andreas
#4 Posted : 20 July 2020 16:54:39
Groups: registriert
Thank you Carl ,Gray appreciate itBigGrin
Forum Support Team
#5 Posted : 20 July 2020 22:16:49
Very nice work Andreas, the sleepers look so much better.BigGrin
#6 Posted : 21 July 2020 14:27:23
It's looking really good.
I'm sure I read somewhere there is ready-made garden railway track that is the right scale for this model. It could save a fair bit of work.Cool
#7 Posted : 21 July 2020 19:25:24
That looks really cool. BigGrin
This page was generated in 0.120 seconds.
