52 Pages <12345>»
#41 Posted : 26 June 2020 12:40:01
Both of the last two junction boxes fitted. They are next to the ammeter and isolator.
#42 Posted : 26 June 2020 12:41:05
That concludes the update for this week.
Thanks for looking in and have a nice weekend!BigGrin
#43 Posted : 27 June 2020 23:58:03
Incredible detailing Phil, truly a work of art.....Love Love .. If this build doesn't end up in a museum then there's no justice in the modelling world..... Cool Cool
#44 Posted : 10 July 2020 14:29:05
Good afternoon from 'The Dockyard'.
More progress has been made in fitting out the aft torpedo compartment.
Attached photo shows the electrical control box for the bilge pump.
#45 Posted : 10 July 2020 14:30:10
Control box painted.
#46 Posted : 10 July 2020 14:31:18
A control valve. All parts are made of styrene rod and sheet and the pipework is a length of solder.
#47 Posted : 10 July 2020 14:31:51
Control valve painted.
#48 Posted : 10 July 2020 14:32:49
Both control box and control valve fitted.
#49 Posted : 10 July 2020 14:34:31
The bilge pump. All the parts i make use various thicknesses of styrene sheet and rod as well as various diameters of solder and brass rod.
#50 Posted : 10 July 2020 14:35:28
Bilge pump painted.
#51 Posted : 10 July 2020 14:36:33
Bilge pump fitted.
#52 Posted : 10 July 2020 14:37:55
The attached photo shows an electrical junction box. The needle file points to its location above the bilge pump.
#53 Posted : 10 July 2020 14:39:26
Next up is a pipe with a bypass line and bypass cock.
#54 Posted : 10 July 2020 14:40:16
All painted and pin washed.
#55 Posted : 10 July 2020 14:41:23
Fitted in place.
#56 Posted : 10 July 2020 14:42:48
Another supply pipe with valve isolator.
#57 Posted : 10 July 2020 14:43:52
Painted.
#58 Posted : 10 July 2020 14:45:38
Pipe and valve isolator fitted. The solder to the side will be attached to a pressure gauge and cut to suit when the gauge is in place.
#59 Posted : 10 July 2020 14:47:11
That concludes this update.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
#60 Posted : 10 July 2020 19:28:04
Very nice work Phil, Love Love just hope you don’t get any leaks when you fire it all up.LOL
52 Pages <12345>»
This page was generated in 0.371 seconds.
