10 Pages <12345>»
1/16 Hobby boss Tiger 1 Options
#41 Posted : 05 July 2020 11:39:26
Markwarren wrote:
Very nice work Phil, modelling at its best. Drool Love Love
Thanks Mark BigGrin i try my bestBlushing cheer`s PhilCool
#42 Posted : 05 July 2020 16:51:17
So i started to add etch which in this scale is quite enjoyable first the missing latches on the stowage bin
#43 Posted : 05 July 2020 16:53:13
then i reworked the kits jack with the abber etch
#44 Posted : 05 July 2020 16:57:25
Very pleased with the jack with the handle left off to attach laterCool
#45 Posted : 05 July 2020 16:59:15
I then did the side skirts which won`t be added till later but wanted to give my soldering skills agoLOL now this is my first attempt at soldering brass which on the whole went ok three triangles to put on each skirt , 4 skirts per sideCool
#46 Posted : 05 July 2020 17:08:32
then reworked the kits extinguisher more soldering here Cool i have decals for these aswellCool quite pleased with the outcomeCool
#47 Posted : 05 July 2020 17:17:17
then a rest bite from etch added the rest of the zimmeritCool
#48 Posted : 05 July 2020 17:24:22
Before adding it to the rear plate i filled the holes and sanded of the moulded on tool Cool
#49 Posted : 06 July 2020 13:16:30
Pictures of the crank base plate and extinguisher before and after modification also the towing clamps but not done these as yetConfused ,the Abber set is quite extensive and you get a lot of turned brass parts in it Cool
#50 Posted : 06 July 2020 13:21:00
You're doing a great job with this Phil, looks fab.....Drool Drool
#51 Posted : 06 July 2020 13:21:20
The missing armoured air vent hood from the engine deck all brass excellentDrool
#52 Posted : 06 July 2020 13:24:24
Thanks Alan BigGrin
cheer`s PhilCool
#53 Posted : 06 July 2020 13:28:24
Just to say i`m building and modifying the extras before assembling the hull etc easier this way and for me i won`t brake bits offLOL Also on looking at Shapeways they also do a lot of upgrades for this scale of Tiger 1Cool
cheer`s PhilCool
#54 Posted : 06 July 2020 13:32:22
As stated this kit is from an R/C back ground and so in the instructions you have to screw the turret to the upper hull via a toothed ring then screw this all to the lower hull Blink i wanted to be able to add the turret after so i set about cutting the toothed part off the ring off then the turret can be fitted later Cool
#55 Posted : 07 July 2020 10:56:11
Here are the figure`sCool
#56 Posted : 07 July 2020 10:58:02
The kits radio operators MG 34 and the Abber one Cool
#57 Posted : 07 July 2020 11:01:19
After Market Decals of Heavy tank Battalion 502 for "Otto Carius" nights cross holder Tiger ace Drool Cool
#58 Posted : 07 July 2020 11:03:24
Turned brass lifting lugs for the armoured exhaust covers and then fittedCool
#59 Posted : 07 July 2020 11:05:52
On the Abber set is the missing rear gun travel lock all from brass even have to make the chain Blink
#60 Posted : 07 July 2020 11:10:42
Then the commanders cupola here i added the missing weld beads along with the Abber periscopesCool
10 Pages <12345>»
This page was generated in 0.418 seconds.
