Brilliant stuff, Alan. Almost there now. Chris
Alan That looks so good and all that tiny detail painting you have done looks so neat. With my Harley finishing in the next couple of months i am tempted to Get this one while its still available (which hopefully it will be). Would have been the surprise on a partworks basis but see that is out of stock And with artesania latina folding cannot see that becoming available again. Hope the rest of it continues as well as it has so far. Tony Happy Modelling
My thanks to all who've looked in and commented, very much appreciated... We're on the last leg now and hopefully this build will conclude in the next couple of days.... @Tony - she's a great kit to put together but does have its challenges. Not one for the feint hearted that's for sure but if you fancy hours and hours of painting tiny details then I'd certainly recommend it. If you do take it on then I'll certainly follow your progress..... Regards Alan
Gandale wrote:My thanks to all who've looked in and commented, very much appreciated... We're on the last leg now and hopefully this build will conclude in the next couple of days.... @Tony - she's a great kit to put together but does have its challenges. Not one for the feint hearted that's for sure but if you fancy hours and hours of painting tiny details then I'd certainly recommend it. If you do take it on then I'll certainly follow your progress..... Regards Alan Thanks Alan. Its at the top of my list right now as its such a well known ship and seeing Your excellent build Has revealed just how detailed it is. Thanks again Tony Happy Modelling
Stage 140 Contents: Flags, Barrel Chocks, Dummy Guns and Decorations
This has been a great kit to put together even though a vast amount of time and concentration was needed especially on preparing and painting the vast amount of decorations. A build I would recommend to all, especially if you like a challenge.... Now it is time to bring this build to its conclusion....
Take the two decorations C182 and C183 supplied with stage. Remove any flash or burrs and apply a coat of primer. When dry, paint the decorations as outlined in the instructions. Glue the two decorations to the front of the stem on the port and starboard sides. Retrieve the six barrels you have left, stain with wood stain of your choice. When dry, paint the bands on the barrels black. Separate all the parts from the chock fret and clean up all the edges. Assemble the chocks to give you two in total ensuring everything is square. Once dry, paint both chock red. Now glue two barrels onto each chock. Now tie the barrels to the chocks with natural thread, passing the thread through the holes in the chocks. Glue the two chocks to the deck, either side of the gratings, aft of the capstan. Glue the remaining two barrels to the deck, up against the bulwarks, forward of the main mast. Secure the barrels to the rails with natural thread. Now prepare all the remaining dummy cannons and gun port lids in the same way as you have done for the others. Now fit the dummy guns and the gun port lids following the instructions in stage 138. Prepare the buckets received in this stage in the same way as those in stage 68, you will need a total of 10 buckets. Glue the buckets to the deck, five on each side next to the shot boxes.
Retrieve the 4x4mm wooden strip and the 3mm dowel supplied in stage 129. You will also need parts FS1 and FS2 from the fret supplied with stage 126. Test-fit FS1 on the strip and adjust to fit if necessary. Cut a 50mm length of the strip and a 205mm length of dowel. Angle the ends of the strip to 70 degrees. Stain all the pieces with wood stain. Now glue the four pieces together as shown in step 24 of the instructions. Note, the flagpole will sit at an angle of 70 degrees from the base. Tie a 5mm block to the top of the flagpole. Take the larger flag from the three supplied and remove the flag from the backing sheet. Place the flag down with the adhesive side facing up. Take a 600mm length of natural thread and place it into the centre of the flag. Press the ends of the flag together and shape around something round like an offcut of dowel. Press more of the flag together and shape on the other side. Proceed until both parts are completely together and the flag looks like its blowing in the wind. Pass the flag line through the 5mm block on the flagpole, then back down and tie both ends off to the flagpole and secure with glue. Glue the flagpole to the deck forward of the transom. Prepare the second smaller flag in the same way, then tie a 5mm block to the top of bowsprit topmast. Tie the flag to the bowsprit topmast. Prepare the third flag and fit it on the main royal mast. The length of line used to tie this flag in place should be over twice the length of the full mast.
Now that the last flag is flying, this completes the Vasa Build... Gandale attached the following image(s):
Alan You have turned out a cracking model. Bit “sad” to see it all come to an end. Looking forward to seeing what you take on next. Tony Happy Modelling
Alan, Congratulations on a fantastic diary. I have been following this one from the beginning and it's very impressive. Can't wait to see the next build beginning. Chris
Well done Alan looks fantastic, you've finally got there. Nice feeling finishing isn't it. I remember finishing the Soleil it was a relief after a long build. Nice to take on something new. Wonder what it is you will do. Hmmmmmm Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks guys, appreciate the kind comments.....  .. My next task is to get some work done on the Standart whilst deciding my next major project. All I'm certain of at this stage is my next build will NOT be a period ship, need to re-energise on something else..... Regards Alan
What can I say Alan, this has been a stunning build and a pleasure to follow throughout. From what I have seen this is not a build for the faint hearted, but has inspired me to have a go at a wooden ship build at some stage, although I will be looking at something simple to get me going. Looks absolutely stunning. Mark Regards Markwarren (Mark) Admin
 Congratulations Alan on a build well done. Your boat builds are always first class, and a joy to follow. You must have your own 'Armada' by now Looking forward to see what you take on next, after Standard Regards Gray
Joined: 11/05/2019 Posts: 10 Points: 30 Location: East Midlands
Stunning build Alan. It looks amazing. Well Done.
Absolutely stunning WTG. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
What a build!! An absolute blinder!! All that detail and the work that has been put into it!! I doff my cap to you Alan. Well worthy to win build of the year this one... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Thanks guys, your comments have certainly been inspirational to me in finishing this challenging build. Always appreciated..... Regards Alan
Gandale wrote:Thanks guys, appreciate the kind comments.....  .. My next task is to get some work done on the Standart whilst deciding my next major project. All I'm certain of at this stage is my next build will NOT be a period ship, need to re-energise on something else..... Regards Alan Alan, what ever you decide to build will be an inspiration to us all I think. Chris
Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Fantastic build Alan. What are you going to do now, watch out for withdrawal symptoms. Well done, one to be very proud of. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
Phil, Alec, thanks for looking in and your very kind comments, always appreciated.... Regards Alan
Hi Alan, This again says it all, this is a truly wonderful build as with your Sots build, also I would like to congratulate on the way you have written your build Diary first class work. Very well done. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
