38 Pages «<3031323334>»
Garth's Black Pearl Options
#621 Posted : 18 June 2020 16:54:28
birdaj2 wrote:
Well those fishing tools you mentioned in one of your earlier posts look really useful.
I ordered up the bobbin reel holder and a set of those tiny pliers - sure they are going to be very useful.
Thank you Tony.
Glad to have been of help.
#622 Posted : 18 June 2020 21:15:07
Your build is looking stunning Garth. A real show piece.Love
#623 Posted : 23 June 2020 14:33:09
Hi Phil,
Thank you for looking in and for the kind words.
#624 Posted : 23 June 2020 14:34:54
Masts & Bowsprit Cont. Part 02
Down to business with the masts, finally feel like I'm moving again!BigGrin
First off, thanks to Mark (the owner of our company) for the loan of his mini lathe. Using the lathe to taper the masts has really simplified the process.
First, I turned down the masts to the dimensions on the plans and then cut everything to size. Please note if you are building from my build. The diameter measurements given in the instructions are not the same as the parts into which they must fit. Cursing So, all the parts that I turned down were too small. I only noticed this when I started assembly. Pity I did not measure first. I had to build-up the parts with thin slivers of masking tape. Other than that, everything went pretty much as the instructions show.
Next, I added the 3mmx3mm blocks under the fighting tops of the fore and main mast for the running rigging.
Lastly, before painting, I drilled and glued in all the eyelets with superglue.
Painting, as with the rest of the ship – matt black with progressively lighter dry-brushing. Remember to clean any paint out of the eyelets once it has dried.
goddo
#625 Posted : 23 June 2020 15:05:06
All looking up to your usual high standard Garth.
#626 Posted : 23 June 2020 17:32:19
That looks neat Garth.
I think making the masts is one of (if not the) most difficult part of the build.
Yours look really very well done.
#627 Posted : 24 June 2020 23:44:09
Excellent work on the masts Garth, certainly a job made a lot easier with the use of a mini lathe but it still requires skill.... Very well done....Drool Drool Drool
#628 Posted : 26 June 2020 12:19:48
Lovely work on the masts Garth. She's coming along very nicely!
goddo
#629 Posted : 26 June 2020 13:47:25
Coming along nicely Garth.
I bought a small lathe some time back and it's been brilliant for tapering masts.
A real time saver.
#630 Posted : 30 June 2020 10:29:52
Thanks for looking in Chris, and for the kind reply.
#631 Posted : 30 June 2020 10:33:07
Hi Tony,
You are right, some of the bits are turned down to about Ø1.4mm.
The other challenge is keeping everything squareCrying
I used superglue & activator here. It seemed to work.
#632 Posted : 30 June 2020 10:35:39
Hi Alan,
Thanks for looking in and for you kind remarks. I would probably still be busy if it weren't for that lathe.
#633 Posted : 30 June 2020 10:36:32
Thank you for looking in Phil and for your kind reply.
#634 Posted : 30 June 2020 10:38:25
A real time saver.
Hi Chris,
I have been looking to buy one (at the right price), unfortunately this one is on loan and will have to go backCrying Crying Crying
#635 Posted : 30 June 2020 10:40:16
Hi All,
Masts & Bowsprit Cont. Part 03, Lashings & blocks
Fitted the blocks and the lashings to the masts.
Remember if you are building from my diary:
- add the 6 extra blocks below the fighting tops below the main and fore mast
- add the extra block on the fore mast for the jibs running rigging
- add the extra blocks on the bowsprit for the additional stay and the jibs running rigging
- start the bottom lashing on the main mast about 5mm higher than in my drawings. It got in the way of the capstan.
Apologies for all the different colour casts in the images. I was out on the veranda on a windy day. The clouds would come over, next bright sun, then cloudy again …..Blushing
#636 Posted : 30 June 2020 13:41:56
Those masts are turning out great. Super work.
goddo
#637 Posted : 30 June 2020 13:50:46
[[/quote]Hi Chris,
I have been looking to buy one (at the right price), unfortunately this one is on loan and will have to go backCrying Crying Crying Kind regards, Garth[/quote]
Hi Garth, the lathe that I bought is a lot more basic than the model in your photos.
I got it from my nearest model shop in Windsor and so far, it has done all that I have asked of it.
I have been using a sanding block to taper my masts and booms and with a bit of practice they fit nicely.
Maybe not as professional as some but it's fine for me.
#638 Posted : 30 June 2020 15:14:03
Continuing along very nicely indeed.
You are getting a very nice effect with your paintwork as well.
Hope it all continues well.
#639 Posted : 01 July 2020 14:26:16
Hi Malc,
Thanks for looking in and for the kind words.
#640 Posted : 01 July 2020 14:29:45
goddo wrote:
Hi Chris,
[/quote]
Hi Chris, I have also used a sanding block. I stuck some automotive production paper - the type used to smooth body putty, to a block of supawood. That tapers it down in no time.
