Stem post - Issue 44 Options
stevew
#1 Posted : 22 June 2020 16:35:41
Rank: Beginner Level 3
Does anybody know the size of the doweling for the upper strip on the stem post. The doweling is missing from my issue, and I haven't been able to get hold of any at de Agostini
z8000783
#2 Posted : 22 June 2020 16:44:04
Groups: Unapproved
The instructions say that it is 3mm.
stevew
#3 Posted : 22 June 2020 18:24:41
It's the diameter of the doweling I need
#4 Posted : 22 June 2020 19:18:31
Diameter of the dowel is quoted in stage 44 of the Official build as being 4mm. The dowel was supplied in stage 43.....
https://forum.model-spac...aspx?g=posts&t=1846
stevew
#5 Posted : 23 June 2020 09:22:34
Thanks Alan, as I mentioned this piece was missing from my issue 43
goddo
#6 Posted : 23 June 2020 11:17:02
Steve, As you say, the dowel for the stem post is stated as 4mm diameter and 20mm long in stage 43.
If DeAg can’t help you, maybe a modelling shop that sells timber would be the next step? A small offcut in back of the shop maybe?
Or even a DIY centre would have some short dowels used in flat pack furniture that could be sanded down.
Just a thought.
Good luck.
GilShapley
#7 Posted : 23 June 2020 15:03:26
If all you need is a small length of 4mm dowel PM me you address and I drop some in the post, say 40mm should be enough
Gil
Current Build:-
