4 Pages <1234>
Hatchets Build the Bismarck Options
#41 Posted : 06 September 2011 23:05:28
Looks great Ian Cool BigGrin
#42 Posted : 06 September 2011 23:09:06
thanks Mike
#43 Posted : 14 September 2011 22:46:06
Hi guys
i have added another load of pictures.
bridge wings have been added.
forward deck and range finder and radar mast.
range finder and radar above forward search light deck.
ships bell on aircraft hanger.
stern range finder and searchlights.
stern range finder and radar mast.
BigGrin Ian
Tiswas
#44 Posted : 15 September 2011 22:46:08
Looking good Ian, coming along nicely.
TIS
#45 Posted : 15 September 2011 22:51:30
Good stuff BigGrin Cool Ian
kas
#46 Posted : 15 September 2011 23:01:21
Rank: Amateur Level 1
Looking good so far Cool
#47 Posted : 16 September 2011 17:15:35
Thanks kas
#48 Posted : 17 September 2011 00:52:05
Thanks mike and tis for the kind comments Ian
Cool
#49 Posted : 23 October 2011 22:32:26
Hi guys
i have posted some more pictures of recent work done on my bismarck.
cat walks have been added round the gun turrets.
anchor chains have been added.
funnel and aircraft hangers have been added
alraldo aircraft ramps.
mast and signal station added.
various rope drums added to deck.
hope you enjoy the pictures Ian.
Sid
#50 Posted : 18 September 2012 11:45:29
Rank: Newbie
Hi friends
Well I was looking at menu Bismarck builds over the last month or so, just to get an idea on how the Hood remote control boat may be structured, and some are amazing, the details are superb.
Sid
#51 Posted : 18 September 2012 14:13:44
Hi Sid thanks for the comments.
Just a few more bits of rigging left to do, some cranes and ships boats to put on. and 300 fence posts round the sides. and a visit to the bath tub to work out internal ballast. Ian BigGrin
saintsman123
#52 Posted : 18 September 2012 15:11:48
great work ianBigGrin
Come on you Jimmies
#53 Posted : 20 September 2012 14:43:22
Hi bob thank you for your comments Ian Cool
Mustang
#54 Posted : 31 December 2012 18:55:57
Hi all and a Happy New Year to you. BigGrin
I have just started to build my BismarckBlushing, as I'm just about to finish the Flying ScotsmanLaugh .
I have a question what is the best was to straighten a twisted Hull base as you can see from the photo I have desided to start the Hull by joining all the parts together fist before adding the ribs but I have had to screw it down inorder to try and remove the twist's.
I first wetted the wood the laid batterys across to straighten but there was still a twist so I then screwed it to a old piece of wood which is flat and then used the hair dryer to try and dry it out is this right .
I've build ships before but never a soild flat bottom one.
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
denissimo
#55 Posted : 31 December 2012 19:05:37
I had a similar problem with my Yamato.
I steamed the whole lot, screwed it back down, and let it dry out naturally.
Then after adding the keel and the ribs, its perfectly flat.
Model boats built so far:-
Billings Cutty Sark
Scratch built twin IC RC Vosper MTB.
Scratch built rc electric hybrid.
Scratch built rc IC hydrofoil (ran happily on snow as well as water!)
Plus numerous numerous RC planes.
Under construction
Sovereign of the Seas!
1200:1 HMS Victory (by Mantua)
The Battleship Yamato (seriously considering building as an RC model)
Mustang
#56 Posted : 31 December 2012 19:56:19
Hi denissimo.
Thank you for your info, I wasn't total sure if this would work so if it doesn't work I will dig out the steam cleaner and give it a go.
To build:-
denissimo
#57 Posted : 31 December 2012 20:15:20
Hot water should still work, but as I said, let it dry out naturally after you have screwed it back down.
Dont unscrew it from your board when its dry. Attach the keel and ribs etc while the base is still screwed down.
That will hold it straight and true when it comes to the time when you do have to take it off the board.
Billings Cutty Sark
Under construction
#58 Posted : 01 January 2013 01:27:35
BigGrin Hi Mustang
I agree with what Denisimo has recommended but I would also do all the planking that's possible before unscrewing the keel plate
#59 Posted : 07 January 2013 14:21:38
All of the above methods should work. You could also soak part in warm water and place between two large tiles with rubber bands to clamp it down and leave the part to dry naturally. I have used this method and it works OK hope this helps Ian.
Mustang
#60 Posted : 21 May 2013 19:22:08
Hi all, this is how far I've got.
I decided to do the decks first before the planking.
But there only on temporally.
This is how far I've got with the planking while it was still secured to the build board. But now I've removed it from the board this is how it looks.
The last picture look's a bit on the tilt but its just the angle I took the picture at.
To build:-
4 Pages <1234>
This page was generated in 0.163 seconds.
