First Order, Special Forces Tie-Fighter Scale 1:12, Conversion to a Drone Options
Wabie
#1 Posted : 21 June 2020 13:27:43
Groups: Registered, Forum Support Team Germany, Official Builds, Tech Support, Moderator, registriert, Administrators
Hello everybody,
here is my new drone project,BigGrin
The basis is the Special Forces Tie Fighter from Hasbro in 1:12 scale
the package,
and the content, right on the scales,
out everything that can save weight,
The chunk weighs approximately 4.5kg
The wing height is 65cm and the width is 50cm
A bit much if he should fly, now he still has 1159g
Motors are ordered, a 270W that should be enough
I first designed the brackets for the aluminum frame of the wing, unfortunately the original wing was too heavy and bent,
here the frame construction and where the motors should go,
Here the construction for the motors,
both sashes are finished in terms of frame,
I have taken the wing mount from the original
this is how the propellers are seen in the model at the end, I think almost not at all,
here is my switch solution for the model, because the battery cannot be easily accessed,
and the current building stood,
it continued with the positioning of the electronics,
I thought about building a kind of rack in the cockpit, where I can then firmly install all parts of the control,
the lower beam,
the top bracket with the handrails,
here from above, through the hatch,
and from the front through the windscreen,
the rack is fixed to the top of the cockpit,
The NAZA module has a status LED, which should be visible on the model at all times so that you can see which flight mode you are in or whether there is an error.
This LED is also the interface to the computer to configure it and should always be easily accessible.
I decided to position it under the model,
that housing,
mounted here on the bottom,
the platform for the NAZA module is already finished,
I fix this with a Velcro strap so that it does not fall out of its holder during the flight
That’s it from this construction site
sequel followsWink
I wish you all a nice Sunday and stay healthy Smile
Alle Berichte sowie alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung/Zustimmung meinerseits. © Stefan
Forum Support Team
https://m.youtube.com/watch?v=qIC4f1LE86w
MfG Stefan
#2 Posted : 21 June 2020 18:59:21
Stefan
That looks really good.
Keep thinking how useful those 3d printers are but each time i am “brought back to earth” realising i do not have the skills to work out those sort of designs as you have with your build.
Hope it all keeps going well for you.
#3 Posted : 22 June 2020 18:10:27
Amazing work.Following this with great interest
#4 Posted : 23 June 2020 08:41:49
Excellent work Stefan.Love Love
Coser
#5 Posted : 29 June 2020 21:36:22
Wabie,
You, sir, are a real model engineer! My hat is of to you, that is amazing work, and I wish people could buy those in the shops.
Current Builds
Hachette: T800 Endoskeleton
Finished Builds
This page was generated in 0.193 seconds.
