Stage 5-8 Install the upper deck.    Know between stage 8 and the finished model there are no instructions about removing the upper sections of the ribs  So I just sanded them down. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
Stage 9 make the base unit.  Would you believe there are 16 piece to make this little base unit. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Stage 10 cut the rudder hole.  Stage 11 make the rudder.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Stage 12 make the wheel control.  Stage 13 make the mast support.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Stage 14 add the upper wall tops.  Stage 15 add the mast support.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Stage 16 finished.   I've not added the support beams at the moment as I want to see what the centre section model looks like, possible build it on to this. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
My finishing touch I added a mast.   I hope you enjoyed this little model. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
What a great little kit.  Excellent work. Mark Regards Markwarren (Mark) Admin
What a super job you've done with this little kit, looks fab..... Very well done.... Regards Alan
