16 Pages «<56789>»
Malc's 1/12 Alfa Tipo 158 Options
#121 Posted : 05 June 2020 13:08:36
Interesting detail on the dash is this part number E18.
I could see where it goes but had no idea what it was. I checked with other MFH builders and got the answer.
Do you guys know? No prizes but I found it an interesting item from this era ...
#122 Posted : 05 June 2020 14:59:28
Unsure Oil tempetature guage?
#123 Posted : 05 June 2020 17:49:59
Well deserved "featured build of the month".
Keep up the good work. ThumpUp ThumpUp ThumpUp
Guess at fuel gauge.Crying Crying
#124 Posted : 05 June 2020 19:01:06
Thanks guys..but no you're both wrong BigGrin
#125 Posted : 06 June 2020 09:40:12
Very nice work Malc. Congratulations on the feature build, well deserved. Love Drool
BTW is it a clock?
#126 Posted : 06 June 2020 09:46:26
It looks like a badge of some kind...
One of the Saints?
St Christopher?
Roy.
#127 Posted : 06 June 2020 21:36:50
One of the Saints?
St Christopher?
Roy.
YES... well done Roy. I was completely mystified until I was told. St Christopher patron saint of travelers ( and some other things ). Was apparently put on the dash' of these Italian cars at the time.
Once you see the outline it's clear.
#128 Posted : 06 June 2020 21:38:36
#129 Posted : 11 June 2020 22:44:17
Just caught up with this and you're doing a fantastic job Malc! Top notch!Love Congratulations on 'build of month' too. Well deserved! I've often thought about buying an MFH kit and your build has certainly wet my appetite!
#130 Posted : 15 June 2020 19:37:08
Cheers Phil. These MFH kits certainly deliver some challenging moments but are great fun.BigGrin
#131 Posted : 15 June 2020 19:41:16
The engine is now installed ( 16 bolts on the chassis brackets + some CA ). I'm installing the radiator pipes prior to completing the radiator itself.
Also added the surface effect aluminium sheet to the firewall using the same method as on the dashboard. Distributors / magnetos? added but yet to be wired.
#132 Posted : 25 June 2020 19:54:34
The radiator assembly gets this slotted grill made from PE sections. The longer part gets formed and "clips" into the front of the radiator. There's a mesh section front and rear of the radiator body.BigGrin
#133 Posted : 25 June 2020 22:44:26
Incredible detail, and excellent work.Love Love
#134 Posted : 01 July 2020 14:23:18
Hi Malc,
Great update!!! Its looking fantastic.
(I like the trestles holding up the front endLOL )
#135 Posted : 01 July 2020 21:02:34
it looks stunning.you should submit some pictures to Mr Hiro to put on their website.
#136 Posted : 07 July 2020 19:07:23
Thanks Guys. Appreciate the interest and comments.
#137 Posted : 08 July 2020 12:36:14
The body panels are aligned in part by fitting 0,5mm pins and tubes at some of the joints. I will only finish these sections after most of the construction is done on the chassis.
#138 Posted : 08 July 2020 12:39:19
#139 Posted : 29 July 2020 19:31:57
Now that I understand how the body panels will attach. I've started to assemble and bond the parts together. Front and rear corners plus bulkheads.BigGrin
mwb
#140 Posted : 29 July 2020 20:25:34
That is a work of art Malc. You are really doing that kit justice.
wyatt
Guest (9)
16 Pages «<56789>»
