 Rank: Pro     Groups: Registered
Joined: 09/08/2011 Posts: 399 Points: 1,168 Location: Hertfordshire
Hey guys, I had a stroke of genius the other day regarding the overall size of the finished model I printed off a 1/8 scale plan of the car and pasted it into a storage container This way when I finish a part, I can put it into place of where its gonna end up I think it looks good too, seeing the car come together! Just thought I'd share this, I've attached an image to make it clear what I'm talking about!  The Brawn BuildWentworth Court Dolls HouseThe MP4/4 Build[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
Good Tip Heinzy MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 08/03/2011 Posts: 245 Points: 726 Location: Norwich
brilliant idea, i like it  Well spin my nipple-nuts & send me to AlaskaCurrent Builds:McLaren MP4-23Finished007's Aston Martin DB5FinishedMillennium FalconR2-D2BTTF Delorean (Maybe)
Dude do you have a local pub?
Austin wrote:Dude do you have a local pub? lol no I'm a surveyor! What made you ask that? The Brawn BuildWentworth Court Dolls HouseThe MP4/4 Build[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
Just thought you might have a bit to much spare time to come up with ideas like that heinzy, lol.
Joined: 01/07/2011 Posts: 383 Points: 1,194 Location: Birmingham
I've been doing much the same but taking pictures after each delivery. Then i got a display case to put it all in rather than fiddling about with ordering it each time! The below pictures are what i currently have! File Attachment(s): Case.jpg (1,419kb) downloaded 119 time(s).
only1ianuk wrote:The below pictures are what i currently have! Are you doing the SWB version? Think you might stuggle with the Display case, as nice as it is...
SWB? Sorry im fairly new to models. I think i'm alright with the sizings as Deag gave us the length then worked out the width from what we've got and worked out the height is about double the wheels. It should fit nicely with any luck!
Just have an active mind! That display case looks the part, did you make it yourself or was it made to order? The Brawn BuildWentworth Court Dolls HouseThe MP4/4 Build[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
Made to order. Least if it is wrong i've got a few 1/18's which will happily fill it!
Joined: 29/03/2010 Posts: 190 Points: 512 Location: Lytham UK
Hi Ian... >>>Made to order. Least if it is wrong i've got a few 1/18's which will happily fill it!<<< I would love to know what company you got the display case from as it looks great and would like to build a car next and diplay in a case as good as that one you have ? best regards, Ian Ian Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas Wish list: Bentley Blower http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
Warthog wrote:only1ianuk wrote:The below pictures are what i currently have! Are you doing the SWB version? Think you might stuggle with the Display case, as nice as it is... Short Wheel Base :-) Just looks small but if you have gone by the dimensions given then I'm sure it wil fit fine
I thought the same warthog, it does look a bit short but hopefully it will be fine for Ian. Fingers crossed Ian.
The inside dimensions are L640mm x W300mm x 200mm. I gave a bit extra in terms of size just to make sure, Plus i've got a 1?43 scale to go inside with it! I got the case from http://www.modeldisplaycases.co.uk. The guy is really good as well!
only1ianuk wrote:The inside dimensions are L640mm x W300mm x 200mm. I gave a bit extra in terms of size just to make sure, Plus i've got a 1?43 scale to go inside with it! I got the case from http://www.modeldisplaycases.co.uk. The guy is really good as well! You should be fine then as the Model is supposed to be 594 mm long and I would say 200mm wide... I have a few cases I made with a couple of 1/12th in so I'll wee if they are good enough and make a few more..
