Wabies Showcase for LaFerrari 1:8 Options
Wabie
#1 Posted : 24 May 2020 18:27:42
Groups: Registered, Forum Support Team Germany, Administrator, Official Builds, Tech Support, Moderator, registriert
Hello all,
i am the new FST Member Germany, here my Showcase for the LaFerrari from Model-Space, i hope you like it.
I once thought about the showcase, such a model must necessarily behind glass, if only because of the dust!
I started looking and found what I was looking for.
I found the right one at Sora.
https://www.sora.de/vitrinen/
There you enter how big, how long and how high your showcase should be and you will be told what it will cost.
my Size 800x500x400mm Smile
This has now arrived well packaged, including a Phillips screwdriver
,Wink
here the connection of the acrylic glass plates, these are screwed,
only the showcase was really boring, so I had to bring out a highlight BigGrin I decided on a traverse,
Here are the designs of the corners and the column connections,
I then printed the supports and cut the brass tubes,
times tested, fits !!!
It went on with the remaining trusses,
somehow you have to illuminate the model, Wink so spotlights were needed, these are equipped with a 1W LED and a lens for surface or a lens for spotlights, 18 spotlights are planned. These are designed and printed by myself,
You also get the display case with a base plate and a back wall. Since I wanted something special, I built the base plate myself and designed and glued it with the help of a good friend,
here the draft, beautiful white marble with joints,
The Print,
and finally the floor was laminated to a high gloss,
then the back wall was printed, the whole way round, because the print is to be glued on from the outside,
the display case prepared for pasting,
to adjust,
Remove carrier foil,
and moisten it nicely so that the film can be applied without bubbles and the air pockets get shaken out,
check again if everything is correct,
position and scrape out the air pockets,
let it dry first, Wink
made a test, everything has to be right,
everything worked, the showcase fits, the logo is in the middle, the bottom is the right size Laugh
Now a little eye catcher, the base plate is illuminated with an RGB LED strip, here the lighting test,
The LEDs and lenses for the spotlights will be delivered next week, then continue here.
To be continued BigGrin
I wish you all a nice rest weekend and stay healthy. [Smile]
I hope my English is not so Bad, I translate with Google
Alle Berichte sowie alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung/Zustimmung meinerseits. © Stefan
Forum Support Team
https://m.youtube.com/watch?v=qIC4f1LE86w
MfG Stefan
#2 Posted : 24 May 2020 18:46:50
A really great idea and amazingly executed.
Look forward to seeing the end result.
Love
mwb
#3 Posted : 24 May 2020 21:13:58
That, sir, is beyond amazing. Well done!
#4 Posted : 25 May 2020 09:07:33
What a great show piece. Looking forward to seeing the spotlights working soon.Love Drool
#5 Posted : 25 May 2020 19:12:02
That's a brilliant idea. !! Can't wait to see it finished.
andali15
#6 Posted : 26 May 2020 07:50:03
Stunning absolutely stunning. Andy.
#7 Posted : 26 May 2020 08:27:35
That looks stunning, credit to your skills....Love Love Love
Wabie
#8 Posted : 26 May 2020 08:34:38
Thanks everybody,
I appreciate it very much.
Greetings from Germany
Forum Support Team
MfG Stefan
#9 Posted : 26 May 2020 14:41:43
Fantastic job.All yuo need now is some 1/8 supermodels to pose around the car!!
#10 Posted : 26 May 2020 20:30:39
That is a superb looking caseCool look forward to seeing the end result.
admin
#11 Posted : 26 May 2020 21:49:07
Thank you, Stefan! This is just amazing modeling.
Stefan has some absolutely amazing build logs going over on the German side of things. If you use Google Chrome, you can get it to auto-translate. I can’t recommend having a look strongly enough!
Wabie
#12 Posted : 03 June 2020 17:06:22
Hello at all,
here the Final pictures from My Show Case,
the only i must do, is Print the corners for the Floor
I installed small boxes in the upper rear corners, these are fed with a Bluetooth module with music or other sounds
when the corners are done i take photos for the gallery ThumpUp
Greetings from Germany and stay healthy
Forum Support Team
MfG Stefan
#13 Posted : 03 June 2020 20:02:48
Tremendous work, looks stunning. Love Love Drool Drool Great work Stefan.
andali15
#14 Posted : 03 June 2020 22:21:51
Superb work. You should be proud of what you have done. Andy.
#15 Posted : 04 June 2020 11:47:09
That is a really cool result... Amazing.
This page was generated in 0.260 seconds.
