This is looking fab, the more I see it the more I'm impressed with it..... Lovely work.... Regards Alan
Hi all thanks for the comments. So P2 Step 1, Add the last three ribs to the stern area.  Step 2, Add the three rear stern sections and a small side piece.   My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
Steps 3-5 just show that you need to sand down the outside of the model, in one of the photos is shows a person using a big wood file  the width of a thumb This stage I wasn't looking forward too, this is where you could break the model   But as you can see its still in one piece. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Stage 6-7 is just to cut a small piece of the bottom of the last rib.  Stage 8 was to add the first lot of planks to the rear of the model, but I forgot to take a photo sorry. Stage 9 build a little shaping unit.  This is used to help shape the transom. Step 10 shaping the transom.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Step 11-12 adding the transom first layer  Theres a small gap as the instruction tell you to make sure the transom lower edge is inline with the top edge of the piece we already installed. If it wrong then I'll just add some small pieces of wood. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Looks good, considering its size. Well done so far. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Step 13 We start to add the outer planks.  Step 14-15 We have to cut out the gun ports.    My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Step 16 Finish adding the planks.    Thats page 2 done. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So onto page 3.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Page 3  no not that type  Stage 1 Just sand down the outer planks. Stage 2-10 Was to install the transom parts, your meant to use the small jig but personally its a waste of time. I just glued each piece in turn to the frame work on the ship.  I've also sanded down the top parts as they where in the way of the clamps and would need to be removed later anyway.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Stage 11. Sand down the inner ribs.  Stage 12. Add some more darker planks.  Stage 13-14. Add the lower deck section.  For each if the decks they give you a piece of ply to hold up against the frame work to show where the decks should go. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Stage 15 last on this page, you build the next deck.  Now your meant to build this outside of the ship frame, it was a pain to try and line it all up and to then have to sand it all down I could see it breaking. So I would recommend building it inside the ships frame. Thats it another page finished. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Page 4.  Stage 1-2, install the second deck.   My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Wow this looks really great.Excellent work and it is so small.
This is look fab and a very interesting build to follow.... Very well done..... Regards Alan
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Excellent work!!! This is certainly something different. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Looks excellent, very nice work. Mark Regards Markwarren (Mark) Admin
Thanks everyone for looking in and the kind comments. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Stage 3-4 Installing the next deck.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
