5 Pages <12345>
1848 Stage Coach Options
#41 Posted : 23 May 2020 10:29:19
Stunning work, keep the pics coming.....Drool Drool
#42 Posted : 23 May 2020 16:56:18
Hi wonderful job your doing on this kit,cheers mick.BigGrin
Mustang
#43 Posted : 23 May 2020 21:54:19
So working in the frames has hit a bump in the build.
These are the Walnut piece of wood to be used, I've already started using some as in the darker shade..
So the 8mm wide top, !0mm wide middle and the 12mm wide bottom.
As you can see theres quite a difference in the colour, looks like the tree had a midlife crises and decided to change colour.
So at the moment this is on hold, I've ordered some piece from a shop of 8mm and 10mm wide in 1m lengths 2 of each so I'm hoping I can better match what I've already used.
Why the manufacture allowed this is ridicules, I tested 2 of the bits and one vanished there is a big difference in shade/colour.
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
admin
#44 Posted : 24 May 2020 03:16:49
The color difference is due to some being sapwood (light) versus the heartwood (dark) If you can find them there, get some Transtint Dyes. They can be used with both Denatured Alcohol, or water. I use them for my wooden canoe restorations. The advantage is that you can layer on colors, and build them up until everything is uniform.
Mustang
#45 Posted : 06 June 2020 21:54:11
Thanks for the info, colour change yes I understand thats why I called it a mid life crises LOL LOL I had a look at the stuff you said about it seams very expensive, the replacement wood only cost me £8
To build:-
Mustang
#46 Posted : 06 June 2020 21:58:16
So the replacement wood arrived so I could finish the window and door frames.
I love the instructions for this part, it tells you to leave at least 1mm protruding on the outer face of the model. So what is it 1mm, 1.5mm 0.5mmLaugh Laugh just put 1mm BigGrin.
I did this my using a piece of 1mm brass tubing as a sanding level.
To build:-
Mustang
#47 Posted : 06 June 2020 22:00:04
To build:-
Mustang
#48 Posted : 06 June 2020 22:01:38
So the next stage is to add the outer edging, I curved mine before adding to the model to make it a bit easier. These where steamed and then put in a simple jig.
To build:-
Mustang
#49 Posted : 06 June 2020 22:04:08
The first side went on really good, but the second side had a couple of issues.
Snapped.
So I had to repair it.
And again with the next piece.Cursing
To build:-
Mustang
#50 Posted : 06 June 2020 22:05:27
But I finally got there.
To build:-
#51 Posted : 07 June 2020 08:50:45
Very nice work.Love Love
#52 Posted : 07 June 2020 09:14:58
Very skillfully done. Carry on as you are and this will be stunning.... Very well done....Love Love Love
#53 Posted : 07 June 2020 09:47:39
Brilliant repair there. Superb work all round on this one. It's going to be a real talking point when it's finished.
Mustang
#54 Posted : 17 June 2020 06:55:37
Thank you for dropping in guys.
To build:-
Mustang
#55 Posted : 17 June 2020 06:59:13
Heres the latest update.
Side detail added.
The instructions don't give you much information about this section, so I added some small cross pieces and then sanded in a curve top edge.
To build:-
Mustang
#56 Posted : 17 June 2020 07:01:04
I jumped forward a little to add the doors.
To build:-
Mustang
#57 Posted : 17 June 2020 07:03:18
Windows trim added.
Lower supports added.
To build:-
#58 Posted : 18 June 2020 20:35:16
Wow, That`s looking very tidy.
Nice work. Cool Cool Cool
#59 Posted : 19 June 2020 08:01:01
Lovely work, that is looking very nice.Love Drool
#60 Posted : 19 June 2020 08:16:44
Wonderful work there. A fantastic build.Love
5 Pages <12345>
This page was generated in 0.292 seconds.
