I wanted something different and came across this beauty...  One small problem instructions are not in english  Good job the pictures are ok My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
So the parts.    So as you can see this thing is SMALL. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
These are the first parts of the build but the second step, the first step was to build its building base. Yep this models comes with its own base to build on and you need it   So step 1 and 2 together.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Step 3 was to put 1 and 2 together. Step 4 build the upper section  Step 5 build the side supports.  Step 6 put it all together.    My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Step 7 The ribs, there is a small line burnt into the wood, from what I can make out you have to sand these down to the line.  Step 8-9 Start to build the transom.  Step 10 add more supports.   Step 11 add the upper supports  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Step 12-13 Add more supports again.  Step 14 start to add all the ribs.  They also give you little blocks to add between the ribs, I'll add these once the ribs are in so I can get them all level. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
 What a great idea for a build!!! Never seem one like this before. Will follow with interest Regards Gray
What a super find you've got yourself.. Very different and very interesting....  .. Going to enjoy following this one, especially with the great start you've made..... Regards Alan
That looks very interesting.  looking forward to seeing your next update. Mark Regards Markwarren (Mark) Admin
Hi Mustang, this is a great build and so small follow this one. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Wow that looks like a neat little build. Have fun. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi guys thanks for coming bye. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Worked out a way to install the frames and the spacers at the same time.  I added a small wedge, so each time I added a frame I removed some of the wedge, so keeping pressure on the ribs while the glue set.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Step 14 was to install the second from last rib, Step 15 instructed you to remove the unit from the cradle and install the final rib but I added that while it was still in the cradle. Step 16-17 had you install a piece of planking to the inside, I finally worked out that this was only temporally there to hols the rims together while you sand it all down   My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Next we start page 2 which goes back to step 1. hope that makes sense  so step 1 of page 2 coming soon. Don't worry theres only 4 pages to this build My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Hay admin wheres my medal I've hit over 500 posts well it took a while but I have got there  please could I have an Orange one My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
I’ve got this, and I just received the midsection. These are truly brilliant little kit, and a great value for the money!
Ohhhhhh, I dunno.... Sure! Also, a woodworking trick for you; if you brush a bit of acetone on the laser char, the acetone breaks down the carbon, and makes it super easy to remove.
admin wrote:I’ve got this, and I just received the midsection. These are truly brilliant little kit, and a great value for the money! I’ve ordered the mid section, I’m hoping they do a bow section as it would look great if all the parts where put together like one complete ship. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
admin wrote:Also, a woodworking trick for you; if you brush a bit of acetone on the laser char, the acetone breaks down the carbon, and makes it super easy to remove. Thanks for the info on the acetone. But I sometimes prefer to leave the burn marks, it helps me when sanding down. Once the burn marks are gone I should be ok for the shape. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
