5 Pages <1234>»
1848 Stage Coach Options
#21 Posted : 14 May 2020 12:29:38
Wow - another incredible build of this stage coach!
Mustang
#22 Posted : 15 May 2020 21:48:05
Hi DaDokta, thank you for dropping in on my build. BigGrin
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
Mustang
#23 Posted : 15 May 2020 21:51:27
So I spent the day making up the 3 luggage units, I might make more later Confused
Small case and hat box
To build:-
Mustang
#24 Posted : 15 May 2020 21:54:53
And the ladies strong box, I went a slightly different way.
The lock didn't come with the kit it was something I found online there will be two side handle but they haven't arrived yet.
To build:-
#25 Posted : 15 May 2020 22:09:25
That's really skilful Mustang looking forward to more posts.
Trev
#26 Posted : 16 May 2020 09:41:30
Some very nice skilful work.Love Drool
Mustang
#27 Posted : 16 May 2020 22:39:17
Hi guys thanks for dropping by.
To build:-
Mustang
#28 Posted : 16 May 2020 22:42:48
Done some more today, still glueing the outer strips so nothing to really show.
But I did manage to look at my electronics for the lights BigGrin
I didn't like the idea of a switch inside the compartment and because this will be inside a case when finished I needed something that was particle so remote control Blink
Lights on
Lights off
To build:-
#29 Posted : 17 May 2020 09:37:57
Stunning work throughout..... Keep posting up those pics, its a beautiful build to follow.....Drool Drool Drool
#30 Posted : 17 May 2020 09:52:49
Very nice work. Love Drool
#31 Posted : 17 May 2020 10:02:17
That's a very clever idea Mustang and will show your model of to the best.
Trev.
Mustang
#32 Posted : 21 May 2020 23:31:37
Cheers all for dropping in.
To build:-
Mustang
#33 Posted : 21 May 2020 23:34:12
Coach unit all done with the sides strips.
Rear luggage rack bottom done, I'll secure the leather bit later.
To build:-
Mustang
#34 Posted : 21 May 2020 23:35:14
Handles arrived so the strong box is all finished. BigGrin
To build:-
Mustang
#35 Posted : 21 May 2020 23:37:44
I've been playing about with what to do with the insides Confused so after watching The Hateful Eight again I decided on this.
I've cut them all out but not secured them as I'll need to sand down the edges of the window and door frames.
To build:-
Mustang
#36 Posted : 21 May 2020 23:45:57
So onto the frame work.
The top sections are easy just remember to shape the edges from outside to inside. The lower sections need to curve so I cut them to the size I needed and then placed them in some hot/kettle water so I could shape them.
Wedged them in and will glue them tomorrow, the instructions tell you to install all the frame work then sand them all down so they sit about 1mm on the outside, I personally find it easier to do each one at a time.
So I glued in the four top window frames and then got them to the correct width and I'll do the same with the lower ones, this will also make it easier to install the side frames as you can line them up to the upper and lower frames.
To build:-
Mustang
#37 Posted : 21 May 2020 23:46:57
Thats it for the time being, I'll be back once I've fitted all the frames.
To build:-
kpnuts
#38 Posted : 22 May 2020 06:30:08
Great work
#39 Posted : 22 May 2020 13:12:18
Looking very neat and clean
Trev
admin
#40 Posted : 22 May 2020 23:32:40
This is looking really great!
5 Pages <1234>»
