Fast Purple Flashing Options
r2d2new
#1 Posted : 15 May 2020 16:58:25
Hello, after initialization, r2d2 advances a little, moves the head to the right, then to the left and then positions itself in the center, makes a whistle, always flashes quickly purple and remains like this, it does not reach phase 3 with the blue light fixed. The pressed keys do not work, it only makes sounds; connects with the app, takes photos and videos and all recorded sounds. I am using 18650 melchioni 2000 mAh batteries, the only ones I have in good condition. Can you help me? , Hello and thanks .
#2 Posted : 15 May 2020 22:42:06
Sounds like a cable is amiss or not seated correctly somewhere.
Look at the troubleshooting guide here.
https://forum.model-space.co.uk/...aspx?g=posts&t=32756
r2d2new
#3 Posted : 15 May 2020 23:23:16
Thanks Mark, but I ask you , these melchioni 2000 mAh batteries can be good for R2D2?
#4 Posted : 16 May 2020 09:32:59
Like I said if you are concerned with the burnt patch on the top then don’t use them. The spec on the batteries are the minimum 2000 mAH. Personally, I would ask the seller you bought them from to ascertain whether that is normal and seek his advice before using them.
r2d2new
#5 Posted : 16 May 2020 10:31:42
Mark, the 2000 mAh melchioni are in good condition, they are the samsung 30 q 3000 mAh that show burn marks and I have never put them on R2D2. Apart from that the melchioni are not among the batteries tested with the robot present in some lists of the forums, I knew that at least the batteries must have 2600 mAh. In case, I would order suitable batteries like the samsung which have been damaged, bye.
This page was generated in 0.219 seconds.
