Hachette Lancaster Bomber 1/32 - Looking for spare parts Options
mjhh2
#1 Posted : 13 May 2020 10:50:17
Rank: Newbie
Hi,
I am finally coming to the end of my Hachette Lancaster bomber after working on it slowly for a few years. However when opening issues 123 and 124 I have found that a few the clear plastic pieces were broken (most notably the canopy). Has anyone any spares of any of these clear plastic parts for sale?
Thanks,
Matt
#2 Posted : 13 May 2020 12:58:38
mjhh2 wrote:
Hi,
Thanks,
Matt
Unfortunately getting the latter parts is going to be either a very long and/or lucky search.
If the damage is not to bad you could try a repair with RC Modellers Canopy Glue. It is a thick, flexible glue that is high grip and it dries clear. See link below:
https://deluxematerials....sid=7738b80cd&_ss=r
Sorry can`t be any more help than that.Crying
mjhh2
#3 Posted : 13 May 2020 15:19:45
Rank: Newbie
Thanks for the advice Derek. I have canopy glue that would do an acceptable job - however I wanted to see if there were any parts floating around before using the broken pieces. Cheers.
Matt
#4 Posted : 13 May 2020 18:04:08
Hi Matt.
The only other way you could try if no replacements come to hand would be to repair the canopy and then use it to create a mould in silicone to cast a replacement in clear resin.Although I've been getting into resin castings in a big way recently, I've never tried that myself. The other alternative would be to create a solid resin canopy in standard opaque resin and vac form a clear acetate one over that - again, I've never tried that either!
Best of luck though, you might find the repair itself is acceptable!
Robin
Gingerterry
#5 Posted : 10 July 2022 21:24:51
Rank: Newbie
Hi there, I don't suppose you still have the magazines do you?
This page was generated in 0.547 seconds.
