SAINTED8 Options
SAINTED8
#1 Posted : 13 May 2020 10:01:38
Rank: Newbie
Groups: Unapproved, New Members
Hi all, new to the forum. Hope someone out there can help..
My 3D printer is completed... Apart from the tiny metal switch plates from issue 6 stages 24/25. They have either been lost or I never received them. ModelSpace can't help because of the lockdown at the factory in Italy.
Does anyone know how to get hold of some or, what metal they are made from? I may even try to make them myself if I knew.
Whoamiuk1
#2 Posted : 10 June 2020 10:49:19
Rank: Newbie
Are you talking about part 3 with 2 holes? If so its for the limit switch and you can make one of your own and it should work as long as it is the same size. Best I can see is 6mm X 18mm X 1mm, Maybe try a credit card as long as it dose not let light through it, it should work.
Hope it works for you.
This page was generated in 0.079 seconds.
