Joined: 13/02/2011 Posts: 2,239 Points: 6,837 Location: East Sussex
Thank,s for your comments, Alan. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Just a quick update with both sides of the rear rack finished, now is the time to make and fit the rear back cover which has to be cut from a leather sheet supplied in the kit, first thing is to measure your own work and adjust to that ( reason no to builds are the same) then cut 4 straps to fit around the outside edge of the cover, I super glued mine on being careful not to spill it will stain. This picture shows both sides fitted to form the rear rack sides, Rear back cover on the right.  Next to make and fit will be the back cover, this will have leather straps around with buckles, the buckles have to be made by hand I used 1mm brass and when inserting the leather straps through the buckles be sure to cut them a bit smaller than the buckles, when inserted fold-over halfway and glue, when dry glue and pin to the corresponding places on the sides and back of the luggage rack.  Back cover fitted with straps and buckles.  Regards Trev ps: next will be the roof rails. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looks stunning Trev, superb skills as usual..... Regards Alan
This is such an impressive build!
I also have this one in my stash - but looking at your build i loose any motivation to ever start that project - as i could never reach such perfection! (same is true with that U-boat build of Sticky Wickett)Greetings, Walter
 Rank: Beginner Level 1 Groups: Registered
Joined: 07/05/2020 Posts: 5 Points: 15 Location: U.K.
Trev, I have now completed the chassis thanks to your help. Have started work on the cabin but need some clamps which will arrive tomorrow. This is quite a difficult project for what is referred to as suitable for beginners! Alan
Hi Alcairns, That's a wonderful chassis build well done, I have noticed the brake leaver clamps well done on that, so you must be very proud of yourself. As for the coach build, it can be a bit stressful but no more that you can't handle, just keep posting so I can see where you are. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Alan, Leatherwork not to bad to do, Key is to take your time and go by your own build measurements as every build will be a bit different. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
DaDokta wrote:This is such an impressive build!
I also have this one in my stash - but looking at your build i loose any motivation to ever start that project - as I could never reach such perfection! (same is true with that U-boat build of Sticky Wickett) Hi Walter, thank you for looking at my build and your nice comments, I know that when you start your Stagecoach build, I will follow every stage that you build after your fabulous Victory build we will have a fabulous coach build. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,864 Points: 20,909 Location: Northamptonshire, England
Very impressive work Trev. Mark Regards Markwarren (Mark) Admin
That's looking great. Ken's the name modeling's the game.
Hi tf64, I don't know if you've installed the stirrups on page 55 yet, but personally I believe there in the wrong place. From what I've seen looking at photos these should be just under the main drivers unit near the front just deform the curve. If there installed where the instructions tell us to put them in real life you would need really long legs to rest them, imagine stepping on the wheel or steering unit then trying to step on them where they are in the instructions. The idea is to step on the steering unit then on the stirrup and then onto the front foot rest. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
Very neat work Trev. You have made a lovely job of the luggage rack, it all looks so precise. Hope it keeps going well. Tony Happy Modelling
Hi Mustang, Very good point! as I haven't fitted the Winch box at this stage of my build I had not noticed, but it would be difficult to get up into the seat needs to be looked at (bet a few fell off trying ) Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Tony, Good to hear from you and thanks for your comments. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
tf64 wrote: Hi Alcairns,
Trev.
Thanks Trev - that is very kind of you. Admittedly I have not done everything by the book. Alan
Update: Hatbox,Streering bars, and pivot point assembly. First picture shows the hat box this I cut two 30mm circles from a piece of 2mm sheet of balsa,I then cut 18 pieces of 20 mm 5x1.5 to make the walls,when dry sanded down and stained American Walnut. .jpg?width=1920&height=1080&fit=bounds)   Steering assembly with carriage. The carriage build was very strate forward 3 bars and two ends I have to add more at a later date such as brake lever and clefts, suspension brackets.etc. Sterring took me longer than I would have thought,plenty to think about and make,and keep it all straight, also make and fit the pivot. .jpg?width=1920&height=1080&fit=bounds)     More soon Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, Good to see you back posting on this excellent build. Hope you are well. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek, Many thanks for you comments,hope to post again with in a few days building the boxes to go on the top next. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Trev Nice to see your latest build update. The hat box looks like you have lined it with a patterned paper - it looks very good. Tony Happy Modelling
Tony, Thank you for looking, yes you are quite right I have lined with hat paper from the mid-1800s, found the pattern on the internet although in the kit you should cover with leather I tend to be a bit different and do my own thing.The next part will be a luggage box and ammunition box. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
