Glue Options
riff-raff
#1 Posted : 29 August 2011 21:12:28
I am trying to add some extra rigging using some light coloured "rope" If I use superglue it discolours the "rope". If I use PVA it comes unravelled.
Is there a fast setting glue that does not discolour the rope?
Thanks
Built:
Deepseacodmaster
#2 Posted : 01 September 2011 14:58:19
Thanks
I am also waiting for a reply.
Come on you experts.
Huh Huh BigGrin
First Build HMS Victory and HMS Endeavour
Also Krick steam boat "Victoria"
Cheers
Ivan (Ordinary Seaman)
http://www.old-glossop.com
#3 Posted : 01 September 2011 16:23:19
The very nature of the majority of glues means that they soak into thread, and there lies the problem; PVA should work, have you tried neat PVA?
riff-raff
#4 Posted : 03 September 2011 11:44:27
I understand the nature of the glue Tomick but is there a glue that doesn't darken the tread as much as superglue?
I may have to resort to neat PVA but as the drying time is much longer and the thread I am trying to glue very fiddley I may have to use a peg and clamp jig to hold the long ends of the thread in place before I then cut them to size.
Thanks Tomick
Built:
#5 Posted : 03 September 2011 12:17:48
You could try 'Gator's Grip' glue which is a new to the market and is water based acrylic glue similar in appearance to white PVA, or even 'Formula 560' canopy glue, which is another PVA type glue but is flexible, fast drying and dries clear; its generally used for bonding plastic canopies to almost anything, but it might just do the trick, and to some extent it also depends on what your thread is made up of.
willie
#6 Posted : 03 September 2011 12:58:02
i use this no more nails pva express glue it gives a good bound in 5 minutes for handeling but the last time i reconmend it it was called cheap and nasty
