16 Pages «<45678>»
Malc's 1/12 Alfa Tipo 158 Options
#101 Posted : 08 May 2020 09:35:12
Stunning work Malc, a beautiful build to date.....Drool Drool Drool .. Well done....
#102 Posted : 09 May 2020 13:17:10
Thanks Alan. Certainly keeping me busy.
#103 Posted : 09 May 2020 13:24:37
I've had some success with opening up the louvers on engine bay side panels and Bonnet.
I was just a bit too cautious with the scalpel previously and I've found it is possible to just slice into the leading edge of the slots. A strip of 180 grit paper, cut narrowly, will fit through the opening. I fastened that to one side of a Fretsaw and held the other end onto the saw with my hand. Was then able to slid the panel on the paper and it quickly removes the material from the slot. care has to be taken to get equal material removal across the opening.BigGrin
I did this in a area that was easy to clean up the dust created and wore a dust mask. I once read somewhere that this casting resin is bad stuff to inhale.
#104 Posted : 09 May 2020 14:15:26
Top work Malc, looks an excellent job.Love
#105 Posted : 09 May 2020 16:13:41
Love Drool Love Just LOVE this build!!!
Gray
#106 Posted : 20 May 2020 19:23:06
So I'm still at a mostly dry fit stage but with paints and polishes done as I go through the build. There is a white metal panel that bridges the fire wall and the dashboard castings. It will get painted with the bodywork later. Seems to all fit together quite well.BigGrin
#107 Posted : 20 May 2020 19:27:31
The air intake is this massive trumpet !! cast in two parts. I've given it a polish and balanced it on top of the Carb'.
#108 Posted : 03 June 2020 19:10:28
There's some piping to be done from the pannier tanks and the main rear tank. This seems to be a driver actuated change over. There'll be a lever on that valve when finished.
I've made mock ups of the pipes ( still to be formed from the supplied Aluminium wire ) Just to practice my pipe bending skills ( or lack of ! BigGrin )
#109 Posted : 03 June 2020 19:13:09
Getting to grips with the pipework around the radiator.
#110 Posted : 03 June 2020 20:07:51
Just loving the work you are putting into this.Love Love Love Really great work.
#111 Posted : 04 June 2020 07:53:46
Hi Malc,
Once again, great update!!!
Congrats on "Featured build of the Month" well deserved ThumpUp
#112 Posted : 04 June 2020 10:22:47
Hi Malc, congratulations on "Featured build of the month" looking forward to the next update.
Trev
#113 Posted : 04 June 2020 11:40:00
Thanks Mark. Glad you're liking it.
#114 Posted : 04 June 2020 11:41:06
Garth wrote:
Hi Malc,
Thank you Garth. Appreciate your kind comments.
#115 Posted : 04 June 2020 11:42:37
Trev
Cheers Trev. The "featured build of the month" was a nice surprise.BigGrin
#116 Posted : 04 June 2020 12:05:03
Well done Malc. Well deserved.
Another great update too.Love
#117 Posted : 04 June 2020 12:15:21
BigGrin Hi Malc
Always a pleasure reading your build diary. And congrts on the 'Featured Build'
With the car on those saw horses you would think it's the real thing ThumpUp
Gray
#118 Posted : 05 June 2020 11:33:30
Thanks for the kind comments Roy.
#119 Posted : 05 June 2020 11:34:44
CaptnBirdseye wrote:
BigGrin Hi Malc
Gray
Thanks Gray. Appreciate you following the build.
#120 Posted : 05 June 2020 13:03:04
Many thanks to Admin for the "build of the month" highlighting. It's very encouraging to get other builders comments and advice plus this recognition. BigGrin
The bulkhead / dashboard on this kit takes a self adhesive surface "effect" foil which has to be cut from a square sheet. I found it best to strip the protective layer from the foil backing and tape the foil onto the cutting mat. Adhesive side exposed facing up. Then press the bulkhead down onto it. This avoids handling the flimsy and sticky foil. Once pressed down I cut around the shape with a knife.
Managed to avoid wrinkles in the surface.BigGrin
The individual instruments I'll finish and fit later.
Guest (5)
16 Pages «<45678>»
This page was generated in 0.220 seconds.
