5 Pages 123>»
Tamiya Knight Hauler Options
skyfire
#1 Posted : 05 May 2020 10:40:31
Publisher Medal: Featured Build of the MonthActive Service Medal: 500 post active service MedalBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Bought the knight hauler radio control model truck off ebay.
Quote:
This new 1/14 scale R/C Tractor Trucks Item features an originally designed truck body. Hood, large roof spoiler, interior, and lights (clear orange parts), which have been artistically rendered in exquisite detail. Grill, tank, exhaust and steps have been beautifully rendered with metal plated parts. Kit includes stickers and 540 motor. 7.2V battery pack and R/C system are sold separately.
Basic specifications of the Knight Hauler
Total length: 630mm, Total width: 186mm, Clearance: 19mm, Weight Fully-Equipped: about 3.1kg (without multi function unit) Wheelbase: 476mm Tread F/R: 156/138mm Chassis Material: Aluminum and polycarbonate plastic Chassis Shape: Ladder Type Frame Suspension: Front and Rear Rigid Axle w/Metal Leaf Springs Caster Angle-F/R: 0deg/0deg Camber Angle-F/R: 0deg/0deg Toe Angle-F/R: 0deg/0deg Damper: F/R Aluminum Dummy Dampers Drive train: 2-axle Transmission: 3-gear transmission (gear shifting operated via transmitter) Gear Ratio: 1st gear 32.49:1, 2nd gear 17.76:1, 3rd gear 10.66:1 Diff. gear system: F/R Bevel Gear Diff Motor: RS540 (standard in the kit) Tire Width: F/R both 22mm Tire Diameter: F/R both 88mm Requires eight R6/AA/UM3 batteries for transmitter (sold separately).
skyfire
#2 Posted : 05 May 2020 10:42:04
Box art and gearbox.
skyfire
#3 Posted : 05 May 2020 10:43:09
Chassis well underway.
skyfire
#4 Posted : 05 May 2020 10:44:09
More work on the chassis.
skyfire
#5 Posted : 05 May 2020 10:45:08
Wheels and lights.
skyfire
#6 Posted : 05 May 2020 10:46:08
Chassis is now complete. Next up is the body.
skyfire
#7 Posted : 05 May 2020 10:47:07
Start of the work on the body. Painting will start soon.
#8 Posted : 05 May 2020 13:13:44
Nice big kit to work on. !! looking good. Great Tamiya quality as always I guess.
skyfire
#9 Posted : 05 May 2020 14:14:26
It went together very well. Now trying to decide wether to brush or spray paint it, I have a feeling the spray paint would make it look better, only thing I have not used spray paint before. Also not sure I want to go buying the paint for just one model.
skyfire
#10 Posted : 13 May 2020 11:23:59
Painting has started on the truck. Body will start once I decide what colour to actually paint it.
#11 Posted : 13 May 2020 12:47:27
Laugh Jeez, she's HUGE!
Looks great though. What did you decide on in the end? Brush or airbrush?
Cheers
Gray
skyfire
#12 Posted : 14 May 2020 01:48:19
I decided to go with brush painting, it doesn't need a showroom shine on the body.
skyfire
#13 Posted : 30 May 2020 08:00:11
Painting of the body has started and so far it is going well.
skyfire
#14 Posted : 22 June 2020 11:27:08
Tried brush painting part of the body and the paint just scrapes off with a fingernail, back to the drawing board on the paint then!
#15 Posted : 22 June 2020 11:47:25
OhMyGod Oh no! What are you using for primer?
skyfire
#16 Posted : 23 June 2020 09:55:35
Didn't use one in the end.
I have decided that once I have some funds again, to bite the bullet for the delivery costs and get the spray paint for it from Sydney. It has to come by road as it is considered dangerous goods by airlines!
skyfire
#17 Posted : 26 July 2020 15:20:39
In the meantime, I have started on a container trailer for the Knight Hauler to pull.
skyfire
#18 Posted : 26 July 2020 15:21:36
Suspension is under way.
skyfire
#19 Posted : 26 July 2020 15:22:46
Start of the container itself.
I have lights coming for the trailer and a bullbar for the truck.
andali15
#20 Posted : 26 July 2020 17:14:32
Wow with the trailer attached it will be one long model. Have you got somewhere big enough to display. Following with great interest. Andy.
5 Pages 123>»
This page was generated in 0.199 seconds.
