ModelSpace
Star Wars, Sci-Fi and Space
R2-D2
R2-D2 Discussion Forum
Head Turning to right side on first start up. Help!!!
My R2 on first startup, the head turns to the right and wont stop. I need help please on what to do. I checked all wires and they are plugged in correct. Im at a loss.
It sounds like the lug on the bottom of the dome is not hitting the sensor on the rim. Check the sensors and make sure the dome is seated correctly. Mark Regards Markwarren (Mark) Admin
I got the head to work. The head was connecting to the sensor. So I switched the wires to the sensors and it worked and a new problem came up. The motor in the right leg isn't working. R2 spins in a circle when he needs to go forward.
I would check the the leg cables are seated right, no bent pins and inserted in the right way. Mark Regards Markwarren (Mark) Admin
ModelSpace
R2-D2
