Head Turning to right side on first start up. Help!!! Options
ogre13
#1 Posted : 23 April 2020 19:09:07
Rank: Newbie
My R2 on first startup, the head turns to the right and wont stop. I need help please on what to do. I checked all wires and they are plugged in correct. Im at a loss.
#2 Posted : 23 April 2020 19:38:47
It sounds like the lug on the bottom of the dome is not hitting the sensor on the rim. Check the sensors and make sure the dome is seated correctly.
ogre13
#3 Posted : 24 April 2020 17:24:19
Rank: Newbie
I got the head to work. The head was connecting to the sensor. So I switched the wires to the sensors and it worked and a new problem came up. The motor in the right leg isn't working. R2 spins in a circle when he needs to go forward.
#4 Posted : 25 April 2020 09:44:50
I would check the the leg cables are seated right, no bent pins and inserted in the right way.
This page was generated in 0.078 seconds.
