Andreas wrote:It's always great to look at your models.It always gives me new inspirations. I´m also very interested building the Enterprise. I have the opportunity to buy the Enterprise cheaply from a dealer. He started it, but no longer want to continue. A light kit from the USA is included. But!! it is getting tight in my house. Two rooms are already full and Madame is getting nervous . A lot came together in 8 years. Thank Andreas. I’m getting to be in the same boat with room as well. Although it was one of the smaller models of its kind our there, by the time I’ve build the display case with the electronics, it is going to be quite a size. Mark Regards Markwarren (Mark) Admin
Gandale wrote:Beautiful work Mark, she really does look amazing..... Regards Alan Thank you Alan, still a lot of work to do. Mark Regards Markwarren (Mark) Admin
Steve1701 wrote:i cant get over the shuttle bay doors, work gone in to this is amazing. look forward to more updates. Thank you Steve. I breathed a sigh of relief when it all lit up after I had pieced it all together. The plan is to have the Galileo shuttle flying out of the bay when complete. Mark Regards Markwarren (Mark) Admin
 Looks like flash got his act together and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy, wish he got his act together first time round. Mark Regards Markwarren (Mark) Admin
 Jaw droppingly stunning
Thank you Gray Regards Markwarren (Mark) Admin
Welcome back to the space dock. It has been a turbulent time this week, with fitting the nacelles to the hull. I first painted the nacelles and applied the decals as I thought this would be easier to do separately rather than when fitted. First two of the rear fins snapped off whilst painting, so made the decision to take the other two off and paint them separately. Once the decals were in place and left to dry, I then sprayed it with a satin varnish. The rear dome pieces were placed on last and these were given a high gloss finish, as they are in the original prop. Then came the fitting. I knew it wouldn’t be easy trying to get the ribbon cables through the tight space I had because of the shuttle bay, but I really needed two pairs of hands. Once I had thread them through, I then applied some super glue and pushed them in place onto the hull. All that was then needed was the final piece of the hull to fit over the lower nacelles locking it all in place. Then disaster happened. As I was pushing the hull plate down to lock it, the rear hull split open on the seam. It was like trying to fit a quart into a pint pot. Anyway, not panicking, I re-glued and sanded the seam again, after which it was re-painted. The first pictures are the Nacelles ready to be fitted and the pictures after them are of the original prop. These were used as reference for painting my own. The last one of those pictures are of the Enterprise in the museum after undergoing restoration. The final lot of pictures are it all fitted together and another lighting test after the disaster I had, just to make sure nothing was dislodged inside. The lighting of the Bussard’s can’t be done until the base is made and the circuit board is in place. As you may notice .I have made a jig to hold the model in place for safety. The main dome caps have also not been fitted yet.
More soon
Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Fab build and update. That support frame is a build in itself. Only criticism is you should have painted it black then nobody would have seen it against the black backdrop. We`d all be guessing then how you got it to levitate. Keep it up its looking good. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks Derek. Should have painted it black, never crossed my mind. Mark Regards Markwarren (Mark) Admin
Fantastic Mark, love everything about this build.... Regards Alan
Gandale wrote:Fantastic Mark, love everything about this build.... Regards Alan Thank you Alan  Now to figure out how the base will go together with the electronics. Mark Regards Markwarren (Mark) Admin
Hi captain Kirk would be proud of you,admire your modeling skills greatly .cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Thank you Kev, Mick.  for taking the time to look in. Mark Regards Markwarren (Mark) Admin
 Looking good Mark and very nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thank you Andy Regards Markwarren (Mark) Admin
With the weather as nice as it has been over the last few days and being at home, I have taken the opportunity to do the base of the model. Most of this work was done outside with workbench and table at the ready. I’m glad I did, what a mess I made. The model of the Enterprise is almost complete, minus a few tweaks and the front Bussard domes to install. Next, was to start the base of the model. I have altered a few things from the original drawing I made earlier in this build. The two main alterations are the stand which will hold the Enterprise on the base and the positioning of the speakers and sound effects buttons. The stand will be slightly larger that the original tube based one I had planned, as the amount of lighting withing the model created far more cables to attach to the base that I was expecting. The acrylic schematics has been trimmed to fit; this was not easy. I then attached this to the main base by drilling holes into it and raising it with the metal stands as shown. This will allow the lighting to be placed on the bottom base for the lighting effects. The plan is to finish it off with clear red acrylic edging to give a red glow as well. The other alteration was to move the buttons and speakers to the front of the base. I decided to make it into a Star Trek style computer console. This was made from sheets of plastic card, sanded and moulded into what you see in the picture below. The LED’s show clear but will be coloured when complete. The two slots on the top are for the data chips used in the original series. These will be made from clear acrylic card and illuminated from within the console.
More soon
A little more to the display case done. I am making the case with ease of access to areas that may need servicing in the future. As well as having the main Enterprise model with a push fit front in order to access the wiring inside, I have also made the stand on which it fits to the base removable as well. As shown in the pictures below, I have made the base fixing in the shape of the Star Trek logo. This will be painted gold with a black rim and attached to the stand. The lower half of the fixing will be attached to the base with slots and a hole where the wiring will feed through. The second part of the fixing will be glued to the main stand and magnets on the underside holding it firmly in place, whilst giving access to take it apart should it be necessary. I have also tweaked the computer console with some more buttons from the extra decals that came in the kit.
More soon
Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
I have finished the control panel wiring that will operate the sound effect. These range from the bridge ambiance; Enterprise computer talk and main theme music all from the original series. The stand has also been completed for the model to sit on with the cables running down. This has also been put together with magnets for ease of accessibility. Finally, the under lighting is in place which illuminates the schematics. Just waiting for some parts I have ordered, including the red edging to hide the cables and just to finish it off with a red glow. Not long now before it all gets put together and lots of fingers crossed that it all works on the day.
MarkMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
