Turning a round dowel into an octagon Options
FightingWillie
#1 Posted : 31 March 2020 15:17:55
Rank: Amateur Level 1
I am working on the main topmast and requires that the lower section of the mast be octagon shaped. I tried several times and I can't get to come out right . Is there a technique I could try.
z8000783
#2 Posted : 31 March 2020 15:26:22
Groups: Unapproved
Not sure if you did this but file the dowel into a square first and then flatten the corners.
FightingWillie
#3 Posted : 31 March 2020 15:47:50
No I did not try that I will give it a shot. Thanks
This page was generated in 0.150 seconds.
