80 Pages «<7374757677>»
#1481 Posted : 20 March 2020 17:14:46
Fitted to the left hand side of the compressor.
#1482 Posted : 20 March 2020 17:19:18
Another update will follow next week.
I normally round off my update by saying "have a great weekend and happy modelling", but somehow that sounds a bit trite under the circumstances. So instead, thanks for looking in and stay safe!Blink Confused
#1483 Posted : 21 March 2020 00:04:40
Truly incredible work, looks stunning....Love Love Love
#1484 Posted : 21 March 2020 09:06:09
Incredible work Phil. What film is this going to be in? Love Love
#1485 Posted : 21 March 2020 20:33:29
Loving the build Phil.
I think after seeing all of the incredible details you have added into this one trying to build it as supplied by the partwork will not look at all good as it will show up so much that is missing.
Yours looks absolutely amazing. Mine has gone further and further down the list of "when do I ever think I will get around to building this".
#1486 Posted : 27 March 2020 09:24:06
Thank you very much Alan!
#1487 Posted : 27 March 2020 09:24:33
Thank you very much Mark!
#1488 Posted : 27 March 2020 09:25:09
Thank you very much Tony!
#1489 Posted : 27 March 2020 09:36:32
A little more progress made this week by scratch building a compressed air cylinder. This cylinder is part of a myriad of various sized compressed air cylinders, which i'm currently building and will post updates on these next week.
I started off by cutting to length a 3.5mm diameter styrene rod. With careful filing I shaped the domed ends and I have to say i'm very pleased with the way they have turned out.
The next step was to make and fit straps, front and back using styrene strip.
Following on from this I made the air gauge, fitted to one end and finished off by making the support brackets, again, from styrene sheet.
The attached photo shows the completed compressed air cylinder prior to painting.
#1490 Posted : 27 March 2020 09:37:35
From another angle.
#1491 Posted : 27 March 2020 09:38:51
Photographed in my hand to a give a sense of scale.
#1492 Posted : 27 March 2020 09:39:16
Painted.
#1493 Posted : 27 March 2020 09:40:20
Fitted.
#1494 Posted : 27 March 2020 09:43:00
That concludes this post, another update will follow next week.BigGrin
Thank you very much for looking in and stay safe during these strange times!Sad
#1495 Posted : 28 March 2020 00:13:17
You make it look so easy at times, beautifully done....Love Love
#1496 Posted : 03 April 2020 14:21:12
Thank you Alan. Much appreciated!
#1497 Posted : 03 April 2020 14:24:41
Good afternoon from 'The Dockyard'.
Last week and this week I have been busy scratch building the myriad of compressed air tanks and gauges for firing a torpedo from the aft torpedo compartment.
Materials used are styrene sheet and rod, brass gauze, various diameters of solder and 0.5mm brass rod as locating pins.
The attached photo shows a front view of the air tanks awaiting painting.
#1498 Posted : 03 April 2020 14:25:43
3/4 front right view.
#1499 Posted : 03 April 2020 14:27:31
3/4 rear right view.
#1500 Posted : 03 April 2020 14:28:34
3/4 rear left view.
This page was generated in 0.378 seconds.
