Rossi Build lower cross-member Options
#1 Posted : 11 March 2020 20:47:02
Confused Not really a moan as such, but just wondered if anyone else has had issues when fitting the lower cross-member from Pack 11, Stage 42?
The only reason i ask is that, on mine, the threaded holes are not threaded fully to the end, only half way. This means that the supplied screws sit way proud when attached to the engine. If you see the attached photos, you will see what i mean.
Gray
This page was generated in 0.110 seconds.
