7 Pages <12345>»
Brushwork/Painting. Hints and tips (walkthroughs to follow) Options
Horatio's Eyepatch
#41 Posted : 13 April 2010 10:45:26
Capt S. Are you an advocate of paint over airbrushing? I note your affiliation and upbringing with paint and brush but wondered if, on a project of this size, for the acreage of wood to be painted, would you propose airbrushing?
I, at this stage, am set up with brush, but I would like to garner opinion.
Many thanks and I'm sure I'm one of many following your valuable advice with interest.
captainalan
#42 Posted : 13 April 2010 11:12:21
Capt stedders great posts so far Ive copied them all
just i point the victory paints are water based so they are acrylic as Ive just had a delivery this morning.Alan
Capt Stedders
#43 Posted : 13 April 2010 11:59:48
It's a good question, but having only a little experience with an airbrush, (for really large surfaces I'd probably want an airgun and compressor or, at a pinch, get by with aerosol cans) I couldn't give you a fair answer. Having learned and adopted ways of getting a smooth, even finish with brush and paint, I haven't really had a need to go the airbrush route. I do however use aerosol primers.
As you say, a model of this size does have quite a surface area to cover - so if you feel like investing in an airbrush, it may well come in handy for coating large areas on this and any other models you might make. Here are some pro's and cons of airbrushing that immediately spring to mind.
Airbrush
Airbrush Pro's:
Gives (with some practice) a uniformly smooth finish (provided, of course that you have prepped the surface thoroughly - something that is critical whether you are using a normal brush or an airbrush)
An airbrush can be used to create some very pleasing effects such as blending, weathering and powder effects with little effort (just a steady hand and a grasp of the nozzle and pressure settings. Having said that, I can't think of any situation whilst modelling the Victory where such trick effects would be called for.
To give an example of what can be done with an airbrush on a model (and a HUGE amount of skill) that would be nigh-on impossible with a brush, take a peek at the following gallery.
http://www.coolminiornot.com/86837
The model shown is probably no more than 30cm wide..
Drool
Airbrush Cons:
To avoid spraying areas that are a different colour or finish you will need to mask them off - this can be quite fiddly (although you can use liquid masking for really fiddly areas (cockpit canopies, stern glazing and suchlike - but this in turn has some potential disadvantages with cured liquid mask stubbornly lurking in corners).
There is invariably a lot of cleaning-up after using each colour - washing out the bottles (or cup, depending on the airbrush type that you use), nozzles, airways and suchlike and, if you use enamels or Tamiya acrylics, you'll get through a LOT of expensive thinners Apart from cleaning, the paint itself need to be thinned down, almost to the opacity of semi-skimmed milk.
Another expense is the propulsion itself - you either invest in a relatively expensive compressor (essential if you intend to use an airbrush for your primary painting needs) or you will end up buying a lot of cans of propellant.
To conclude, the choice between airbrush and brush is a personal one - some people swear by airbrushes and, as shown in that link, can pull off some spectacular results.
EDIT:
To put things into perspective, and to show just what can be done with a brush, take a peek at the following link - the miniature pictured (from head to top of base) is barely more than 30mm tall.
http://www.coolminiornot.com/242255
Schnellboots on back burner
Tools.
Allan
#44 Posted : 14 April 2010 10:27:47
The paint set from Cornwall Models for the Victory can it be airbrushed? if so what is the best thinning medium to use?
ALLAN
Capt Stedders
#45 Posted : 14 April 2010 15:25:39
ALLAN
You can (presumably) airbrush with either.
If your paints have a blue Admiralty Paints label you will need to use enamel thinners to both thin the paint and clean up.
If your paints have a green Admiralty Paints label, water.
Just to be sure, open a pot up and have a good sniff - enamel paint has quite a strong smell - similar in strength of whiff to white spirit.
When thinning paint for airbrush use, be sure to stir, shake, stir, shake and shake again enthusiastically for several minutes - I would then find a larger jar or pot and transfer the contents to that before adding thinners. Aim for a translucency similar to semi skimmed milk and be sure to give that a good shaking before it gets anywhere near your airbrush.
Note: you might want to reserve a little un-thinned paint in the original pot for small parts that you'll be painting off-ship.
Tools.
Allan
#46 Posted : 14 April 2010 15:44:19
Thanks for that just wanted to make sure as i am new to airbrushingBlink Blink Blink
Allan
Tarbrush
#47 Posted : 14 April 2010 16:07:26
So summing up. It would seem that airbrush for large areas as the paint can be built up to the required finish or effect, and brush for fine detail to avoid the nightmare of masking up and subsequent removal.BigGrin I wonder if I can find my trusty 3 haired brush from the plastic kit days, or whether I will have to cut down a new one.LOL
Allan
#48 Posted : 14 April 2010 16:09:23
has anyone tried the polyvine range of paints? paints
Allan
Capt Stedders
#49 Posted : 16 April 2010 20:41:41
Here's another handy use for blu tac.
Since I have been feverishly getting stuck into not one, but two carronade kits (one being for my build and the other for use as a painting tutorial and separate vignette), I thought I'd put this tip up early as I have discovered an interesting alternative to bending brass wire into the rings that secure the tackle (rope bits) to the cannon.
Fish hooks!
They're Grrrrreat!
Each one comes complete with a handy eyelet that just so happens, (once removed from the pointy end), to make a perfect alternative to making your own, or using ones that are somewhat out of scale.
The only drawbacks are that removing the eyelets from the small and rather dangerous hooks it results in either the coveted eyelet flies off, never to be found again - or the viciously barbed business end might fly off in the direction of your skin, or far worse, an eyeball (the need to wear safety glasses is therefore something of a no-brainer).
Anthoo, to prevent the loss of the eyelet, I have developed a technique that will ensure that you neither lose the eyelet - or your eye.
Simply press the eyelet into some blu-tac, as shown in the above photo and, (whilst carefully holding the pointy end), cut with a pair of wire cutters - I use an old pair of electrical wire cutters as cutting anything other than soft brass wire would mess my decent set up in no time).
The eyelet will be literally fired into the blu tac, making it possible for you to retrieve it safely (after a bit of digging about in the resulting hole..
Coming tomorrow... How to remodel and paint the carronade.
EDIT: I used one of the supplied brass eyelets for demonstration purposes as I had already cut all the hooks before I realised that this was quite a handy tip...
PS.
If you want to follow the remodeling walkthrough, also appearing tomorrow (for those of us either already wearing an anorak or maybe trying one on for the first time, you'll need the following..
2.5mm diameter styrene rod (or dowling)
5mm diameter styrene rod or tube (or dowling)
.5mm thick styrene card or strip
1x pack of 10x size 14 fish hooks
Greenstuff (Kneadatite), although Milliput will do at a pinch)
?x bucket loads of patience
Tools.
Capt Stedders
#50 Posted : 17 April 2010 19:50:36
How to use this tutorial
Whilst I have used Vallejo Modelcolor acrylics in this tutorial, you can use whatever kind or range of paints you like. The colours in the picture of the paints and materials that I used are very accurate - so simply choose, or mix them from the range of paints that you already have.
You can also cherry-pick the bits of the modeling and painting guide as befits your level of confidence, if you only want to model the Carronade as per the instructions and parts provided and paint the carriage Ochre Yellow with a no-frill approach, that's fine! You will still find some useful tips and suggestions below.
The Re-Modeling
The carriage
1. After gently filing and sanding the laser burn from the wooden parts and giving all the sides and facings a going over with some P600 wet&dry paper, draw a center line along the longest wooden piece
2. Using a scribe (or other pointy thing) mark the centre points and drill two 1mm diameter holes as shown in the pic below. The hole nearest the square (rear) end of the carriage is 1cm in (at its widest point) from the flat edge.
3. Using a steel rule and a (very sharp) X-acto knife* VERY CAREFULLY cut between the outermost diameters of each hole to form a channel, representing the slide mechanism of the carronade carriage. TIP: use lots of moderately light (but firm)passes with the knife - it will take a while to cut through the wood but if you go at it too heavily you will more than likely split the wooden part. (which would be bad). Note: Unless you have nerves of steel, do not try usinga surgical scalpel blade to do this - they are bendy, prone to snapping and IMHO rather scary.
3b. (alternative method of forming the slide)
If you plan on painting your ship, you could alternatively use a junior hacksaw to cut a channel down the centre of the wooden part
In both cases cut no further than halfway down the wooden piece - quite a bit of the channel is covered by the carronade platform. Be sure to square the lower corners of the slide channel - You could use a thin modeling file or some folded abrasive paper.
4. Now is a good time to drill the holes that accommodate the brass rings - if you are following the magazine assembly - simply follow the instructions, If you are going for accuracy then note the positions on the pic of the (almost) finished carronade below and refer to pics of the real things on the carronade thread (General Discussion).
Note: If you are prone to accuracy, then you will find that there are not enough brass rings supplied with the carronade to make the model seen in the pic below. I used size 14 fish hooks from my local angling shop and snipped the eyelets off (as described in yesterdays entry) as they are quite true to scale. (I also used the larger, supplied brass rings but in places not suggested by the mag).
5. Blu-tac the wooden parts to a spare piece of card and give them a coat of sanding sealant, (try to avoid too much going into the hole you have drilled _ I deliberately used an slightly oversized drill bit to compensate) allow to dry throughly, give the pieces a further light dusting with P600, dust off and apply another sparing coat of sanding sealant
Once the sanding sealant has dried give the wooden parts one last dusting with the P600 and glue them together as per the instructions in the mag.
6. Whether you want to glue the tackle points (?) (brass rings) in now is down to you, I'd recommend gluing them in since adding sanding sealant, varnish and paint can fill those tiny drilled holes making it difficult to insert the ring pins later.
The barrel
7. Rather than use the pivot mechanism on the carronade barrel, as supplied, I re-modeled one from scratch using some .5mm thick styrene strip (for the plate) and some 2.5mm thick strip (for the pinion bracket/barrel support) and some 2.5mm styrene rod for the pinion itself (see the second pic in the painting part of this tutorial for a view).
If remodeling your carronade, you will have to break off the metal tab that form the pinion from the barrel - since it is actually a separate part and glued into place it should snap off easily enough using pliers and a bit of force (NOTE: Be careful not to break off the elevation adjuster 'tail' of the barrel in the process).
7b I also enlarged the bore (hole) of the barrel to further represent the large caliber of this gun, made a thin roll of GS and applied it to represent a barrel ring and sculpted a firing vent and sights (see final pic). In the absence of gs you could use some brass wire as also shown in the pic below
Adding the Royal crest and initials on the barrel was easy using the 'stamp' which I made from the original sculpt (instructions earlier in the thread) - small blob of green stuff - press down with stamp - allow to cure and clean up the edges with a very sharp blade and its 'job done!'
Finally; The Wheels
Since I felt that the wheels supplied with the model were a teensy bit big, I cut some 2mm lengths of 2.5mm styrene rod and sculpted some castor brackets with greenstuff (since the wheels are barely noticeable the brackets may have been overkill - the jury is still out on that one
The Painting
Thank you for staying with me so far, this bit applies to anyone who is painting their model.
1. Prime or undercoat the carriage. Because I am using acrylics, I used the last of some Games Workshop 'Skull White' spray primer - but you could just as easily use Vallejo, Humbrol or even some Matte White spray primer from B&Q.
If you are either using acrylics and can't be bothered to buy some spray primer (its worth it but I'm not going to nag you) or if you are using enamel paints, you can brush some thinned, matte white paint instead
2. If using a spray primer, use blu-tac, as before, to tack your completed carriage onto a piece of card and, following the instructions on the can carefully apply a coat or two of primer (I find several light passes, turning the card with the parts I am spraying around several times in the process) works better than one or two heavy coats.
If painting on the primer using a brush you can blu-tac the carriage to the bottom of a pencil or styrene rod which will make it a lot easier to hold while painting.
Why use a primer and why a white one? Because if you are painting a very light colour, especially a yellow hue and don't prime the surface (especially if it's quite dark), You will need to apply a lot of thin coats of paint (or a very, very thick one -which is a no-no) before you get a 'true colour'
Before I get stuck into the painting tutorial proper, Here's a pic of my suggested colours and tools.
Use this pic to either get the Vallejo paints shown or get/mix something similar with the paints you are using. If you haven't got a palette, then use the blister pack that the carronade parts came in (Storing the bits that you have not used somewhere safe.
The Brushes are sizes 1 and 2 Vallejo, Kolinsky sable brushes, not as good a Windsor and Newton Series 7 Watercolour - but a tiny fraction of the price.
Stage 1: The Shadows (No, Cliff! Down!)
With everything to hand , you are ready to start painting - the first thing to do is paint all the iron bits black - whilst it is inevitable that you will get some smudges of other colours on them during the rest of the process (they can easily be touched-in later) the black will provide a better picture of what is going on with the yellow paint that you are going to apply - a better visual reference if you will than the white undercoat.
Next its time to get the shadows in. For this I am using some thinned down 'German Camouflage Black Brown' (I don't like using using black paint for anything other than is actually black in colour - it's too harsh)and since yellow ochre is a derivative of Yellow (with a slightly earthy tint), A very dark brown is called for for the deepest shadows.
Simply apply it in all the corners and where any part meets another one as shown in the photo below.
An interlude; Thinning Paint
As I am going to be telling you to thin down your paint rather a lot in this tutorial, I had better explain what I mean.
Using thinners - be it water, with a tiny drop of washing up liquid in it (this helps the thinned paint flow from the brush better) for acrylic paint, or Enamel thinners for enamel paint - thin down the paint you are using until it has an opacity similar to milk. It will require more coats before you get an even coverage but these will self level (flatten out whilst drying) more easily than a one thick coat - it will also help you avoid brush marks and other visually offensive errors.
Stage 3 - Base-coat
After mixing some Vallejo Flat Brown and Yellow Ochre (approx 15/85 ratio) to get a warm, yellowy-brown colour I painted all the surfaces that will end up Yellow Ochre whilst leaving just a little of the former 'shadow colour' where parts meet. Keep the paint thin and persevere. It may look messy now but...
Stage 4 - Building the colour up
A straight 50/50 mix of Vallejo Yellow Ochre and Vallejo Goldbrown makes quite a convincing 'Victory Yellow Ochre' applying a couple of thin coats of this colour (as before, avoiding the shadow colours) will soon give you a nice even finish
Note: The yellow colour in these pics appears a little more yolky than it actualy is - when the carronade is actually finished I will take a picture with my more serious camera under studio conditions.
Stage 5. Highlighting/Edging
Since we have covered how to get deep shadows onto our model, it is now time to exaggerate the corners and edges of it. If you look at a black&white photo you will observe that is is the varying degrees of black white and grey that define the shapes and edges of the subjects. Since the shadowing we applied first with the very dark brown colour has dealt with the recesses and shadows the highlighting stage covers the 'Pale Greys and whites' that define the edges - in this case a pale cream colour.
Mixing a bit of Vallejo biege with the Yellow Ochre mix from Stage 4 I applied this, suing the edge (not the point) of my brush - as you can see in the following pic, this defines the edges and makes them more prominent.
Finishing touches
The forward 'base' of the carronade (The square wooden bit) was highlighted using a mix of Vallejo Chocolate brown and Beige (9/1) an all the to edges and corners and this was enhanced further with a slightly lighter mix an the very top edges fo the corner.
Whilst Black suggests that a blue/grey highlighting colour might be more appropriate, (and this would be true if the black paint were fresh) I used brown hues to suggest wear on the edges of this wooden part (exactly where the paint might wear in reality)
The Wheels were painted first in chocolate brown and then highlighted using a mix of the chocolate colour and a bit of beige.
Adding The barrel.
Before gluing the barrel of the carronade to its carriage, you'll need to pop the adjuster into its relevant hole at the rear of the barrel casting. It's a bit tricky to keep it in place during this procedure so I used a tiny bit of blue-tac to hold it in place.
I used the thickest type of superglue to glue the barrel into place and did this extremely carefully - since I didn't use the pivot arrangement as supplied with the kit, more care needed to be taken when positioning it.
I then painted the elevation adjuster (crucifiix-shaped piece)in a black/basalt grey mix to represent well oiled steel
Adding few highlights with the size '0' brush to suggest the threaded part.
Thus endeth todays tutorial..
Phew..
Tools.
Zeptrader
#51 Posted : 17 April 2010 22:01:38
As per usual...excellent
Keep 'em coming
Tarbrush
#52 Posted : 17 April 2010 22:13:32
Thanks Capt. Never would have thought of all that. Really puts modelling in a new light.BigGrin Do you do portraits as well?LOL
Zeptrader
#53 Posted : 17 April 2010 22:18:30
I'm waiting for the figurehead to come out, lets see what stedders does with that.
Mike Turpin
#54 Posted : 17 April 2010 22:33:04
Well that was interesting. I received my carronade this morning and after having inspected it, I came to virtually the same conclusions regarding the trunnion mount and the size of the trucks at the rear of the carronade. The kit suggests an assembly with fixed axles for the trucks but when you think about it they should be on the equivalent of castors to follow the training of the carriage and they are much smaller than the cannon trucks supplied.
Unfortunately I have been out all day and only just getting back to the kit which arrived this morning.
However very reassuring that we are thinking on similar lines. I was considering using the trunnion piece suppplied but trying to file it down as far as the hole and then fitting that to the carriage slide, without all the brass bits! Shall have to see how it works out but for now I'm halfway through the windlass for HMS Halifax, started while waiting for 2 and 3, and see no point in rushing, we arn't in any race are we!
Mike T
captainalan
#55 Posted : 17 April 2010 22:57:12
BigGrin no rush for me i reckon in about six months time i'l be ready to start
on Victory build as im starting san fransico 1st in the meantime il be reading everything capt steds says in here about painting as ive found thats what has let me down in the past thanks for your great tuts steds Alan
tom.ganc
#56 Posted : 17 April 2010 23:15:33
Thanks for all info. This thread is briliant and should be sticked.
I haven't started build yet but I need to get all the materials (drills, gs, some fine chain, more paint, some w&d sandpaper and more :) ). As soon as I'm ready I'll get cracking. I can't wait to be honest :)
I hope to get my Issue 2 & 3 on Monday aswell.
P.S.
Can't wait to see more of your job Capt BigGrin
#57 Posted : 18 April 2010 00:19:31
impresed (dofs cap and bows)i lovley replica i will be tackaling the painting and weathering slightly differently hope it looks as good as yours
just a note Halfords white spray primer is a very good product its very very fine and does not clog up detailCool
Horatio's Eyepatch
#58 Posted : 18 April 2010 00:37:18
tom.ganc wrote:
... but I need to get all the materials (drills, gs, some fine chain, more paint, some w&d sandpaper and more :) ).
Halfords W&D packs are great value and can be bought by all the popular grades that we'll be untilising.
Allan
#59 Posted : 18 April 2010 07:00:43
excellent tutorial as usual just a shame no one can put it in pdf as this is something that can be referred to time and time again as painting was always my Achilles heel i am more of a manipulator of wood BigGrinBigGrin BigGrin
Allan
jonny5j
#60 Posted : 18 April 2010 07:23:22
excellent tutorial many thanks
john
HMS VICTORY
HMS SURPRISE
ASTON DB5
MCLAREN MP4-23
Guest (6)
7 Pages <12345>»
This page was generated in 0.315 seconds.
