13 Pages «<45678>»
Micks 1/200 battleship bismarck Options
#101 Posted : 09 March 2020 08:41:30
Nice work Mick, that’s going to be a big ship when finished.Love Love Drool
#102 Posted : 02 April 2020 16:43:55
Hi thanks to all who looked in and left comments
Issue 51
Here we make up the second 38cm gun same as the first one added blast bags from latex gloves. Cheers mick BigGrin
#103 Posted : 02 April 2020 16:46:59
Issue 52
Just another hull plate fix as the many already done before. BigGrin cheers mick.
#104 Posted : 02 April 2020 16:56:43
Issue 53
First of all fit 2 secondary barbettes to the deck, then add details to the second main gun. Then fit the gun Base and Base plate to the gun. Then fit the gun to the barbette, fixing it on via the gear that goes on underneath. Make sure the arrow on the gear faces forward. Cheers mick. BigGrin
#105 Posted : 02 April 2020 17:01:53
BigGrin All looking good so far Mick ThumpUp
#106 Posted : 02 April 2020 17:02:47
Issue 54
Here just another hull plate fix as before, and finally got around to painting the bow deck red and adding the swastika decal. That me up to date with what me got.till next time cheers mick. BigGrin
#107 Posted : 02 April 2020 17:55:39
All looking very good.
My parts are going into storage at the moment fir when i can find time to put it all together.
It was too good a kit to pass up and with all these things if you are not in at the start you miss out.
Hope it continues well.
#108 Posted : 02 April 2020 18:14:20
I have to admit I was skeptical about this when it was released, but the more I see of it the more I like it.Unfortunately its not available in USA, but I am really enjoying the builds posted here on the forum and I think this will be a real showstopper once finished with all the working features.
#109 Posted : 02 April 2020 23:47:03
Making great progress Mick, she's beginning to look the part now.... Very wwell done....Drool Drool
#110 Posted : 03 April 2020 11:32:18
Love Bow deck looks ace Mick. bet you can't wait to get this months issue and get all the lights and radars working Woot Woot
#111 Posted : 03 April 2020 22:25:19
Making great progress with this build Mick and looking really good, well done. I like the way that the red of the swastika markings really lifts the appearance of the bow section, really makes it pop.
I'm surprised that it is included as normally such insignia aren't allowed in this politically correct world - especially in Germany! Or did you add it through your own methods as a personal choice? Blink
Kev.
#112 Posted : 04 April 2020 11:25:45
Hi kev was added as personal choice the decals are from custom decals down under in Australia. As far as I know it still not allowed in Germany, the blast bags are also my addition just from little finger of latex gloves as they need to work ,cheers mick.BigGrin
#113 Posted : 04 April 2020 21:27:40
In that case Mick … nicely done! Cool ThumpUp
Kev.
#114 Posted : 02 May 2020 16:47:52
Hi thanks to all who looked in and left comments much appreciated.
Issue 55
Here we just attach the stepper motor to the underside of the second main gun.cheers mick. BigGrin
#115 Posted : 02 May 2020 16:51:52
Issue 56
Here just another hull plate. Fit as all previous plates.cheers mick. BigGrin
#116 Posted : 02 May 2020 17:16:09
Issue 57
First of all glue in the 2 target finders on the forward superstructure, then glue in the 6 searchlight directors on the same deck.then bend the 2 bits of etch that need bending, then glue on the 2 etch antenna outriggers on the underside of the searchlight platform, then glue in the previous bent support to the underside of the gallery, then the other bent bit floor platform between the support previously fitted.then glue in the other etch outriggers to the underside of the foretop gallery. Then it's put together the 15cm gun and fit this to the deck by fixing the cog from underneath. Then fit the limit switch.now we get to test previous fitted electrics, the 2 radars,and the recoil on the second main turret,then it's swap boards to test the lights. Do not use the board that you tested the radars with or you will blow the lot,use the board that comes in this issue,lights tested are the searchlight, navigation lights red and green, Bridge lights,admirals bridge lights.all mine work fine.cheers mick.
#117 Posted : 02 May 2020 17:24:48
Issue 58
Here we just fit the motor to the first 15cm gun previously fitted, just plug the lead in put the gear on the end of the motor,sit it in the housing underneath the deck and secure all in place with the cover. That's it till next time cheers mick. BigGrin
kpnuts
#118 Posted : 03 May 2020 13:54:17
Great work going on here.
#119 Posted : 03 May 2020 22:34:41
Another lovely update Mick, love seeing the detail come together... The Bismarck has always been a ship I've wanted to build, maybe some day it will happen.... Excellent work...Drool Drool Drool
#120 Posted : 04 May 2020 13:22:56
Wow, that coming on great. That really is showing its size now.Love Drool
13 Pages «<45678>»
This page was generated in 0.295 seconds.
