11 Pages «<7891011>
Vw Golf 2 GTI Tuned 1/8 Build Options
frah2o
#161 Posted : 03 September 2019 08:41:43
I think to have finished the brake system and underbody.
The brake caliper are blank. I made the hole to remind like the original 1:1 caliper
The front caliper have also a strange shape, i do my best to replicate a shape quite similar
I first primer coated the calipers, second silver coat and finally the red paint.
I worked on rear brake distributor adding the joints for rear brake connection
The kit was totallu missing the handbrake cables, i did my best to made it
I placed all the system, just a final little wheatering and i think the underbody is completed
The are 2 defect: the rotation drill of disc. The rc disc are all the same and don't have rotation side
The second is the rear caliper are in the middle of disc. To take the correct position of rear caliper i must made a longer bracket to have right clearence with rear bridge axle. RollEyes
frah2o
#162 Posted : 04 September 2019 07:07:33
I started the work on the interior.
My project is to elimanate the rear seat and add a roll cage.
I modified the trunk floor and seat to have a complete open trunk.
My friend produced a new machined alu air tank for airride system
I also take the rear Delta struts bar (will be modify) to use as fixing for next 4 point seat belts.
I also check the measure for roll cage, i found a rc 1/10 roll cage to modify (erase the light) but that have quite good measure.
#163 Posted : 04 September 2019 07:15:19
Excellent work.Love Love
frah2o
#164 Posted : 06 September 2019 07:52:55
Thanks mate! Blushing
While I wait felt and rollcage, i started the work on door cards.
First job is to correct an hachette error. The kit has diveided door (metal) from inside structur (in gray plastic). Hachette thinked that was part oof door card......on 1:1 golf is part of the door all metal and one-piece. So i "welded" the 2 part with ciano and bicarbonate.
I also stated the work on door cards: i lowewered on front and rear cards the armrest to permit the fitting of a new flat styrene panel.
I tryed to imitate the carbon door cards of Carbontech
I meake 4 hole.
2 for inside cable to open door
1 to apply the belt to pull the door
1 for glass cranck.
The metal wire and yellow belt is only to show...not necessary the final combo material/color
FInally i worked the panel, painted in black and final carbon decal. I'll decide if mantein black pillars or coat also with felt.
A first primer coat to doors to watch some details that need to rework.
frah2o
#165 Posted : 06 September 2019 08:14:10
I quite finished the felt work on modify rear seats and luggage.
It remains to coat with felt the spare wheeks compartment.
I added a yellow belt to easily lift the panel of spare wheel
#166 Posted : 10 September 2019 20:47:15
Another great update from you Francesco. You certainly work hard to incorporate every last detail and to create that ultimate realism in all of your models. Your efforts are definitely paying huge dividends.
Very well done indeed and keep up the good work! Drool ThumpUp
frah2o
#167 Posted : 12 September 2019 07:51:39
Many many thanks Kev
I meake 4 hole.
1 for glass cranck.
#168 Posted : 12 September 2019 09:44:20
You really are going overboard on this build.
It's looking great.
Keep it coming.
Roy.
frah2o
#169 Posted : 13 September 2019 12:26:18
It's looking great.
Keep it coming.
Roy.
Thanks to much Roy, now the last update. Now i must wait some parts to continue my project. I'll spent my time restoring my Mp4/4.
Here the last update reached on my GTI
Dashboard 1/2
I worked on dashboard
All the dash vents are blanked. I drilled out them to give a little more deep and better view.
I self made a panel with styrene to add ob central vent. This panel will be the support for arride manometers.
I threaded the steering column to change the screw with a hex bolt
I remade the shape of the switch behind steering
I repainted the box under the dash and i added selfmade carpets doing with a glasses cloth.
With 0,3 mm alu foil I remade the pedals, i added the skid proof only to throttle and brake pedal.
frah2o
#170 Posted : 13 September 2019 12:27:13
Dashboard 2/2
The column steering cover had a hole without nothing. I add a red rivet to simulate the starting switch.
With shrink i self made the cover for steering hub.
I used a Delta steering wheel, i sprayed black to try recreating a flocked view on crown.
I painted in alu the spokes and added Momo decals and the yellow centering stripe.
I finished the work on extra manometers for arride.
frah2o
#171 Posted : 25 October 2019 16:49:58
I little work pause on a Delta commissioned by a client
It’s arrived an rc 1/10 roll cage
I started to work on it: i cut the rear plate to insert the tube inside the rear trim
With lego brick i started to calculate the remaining tube to add to central pillars of roll cage
#172 Posted : 25 October 2019 17:46:16
Looking absolutely brilliant.
A thought for the future - you can make your own roll cages using a cheap guitar lead with the 'core' pulled out, and a nice thick copper 'earth' cable from 32amp mains wiring pushed inside.
It bends to shape, is nice and strong, and is real rubber so it looks good and feels real.
The pics here show it before I added seam joins using a black stained glass window pen...
frah2o
#173 Posted : 26 October 2019 09:45:45
Thnaks Roy, your lead guitar trick is very smart and useful. I save your tips and sure i use for next 1/8 build.
Tnaks so much for sharing this!
frah2o
#174 Posted : 02 March 2020 12:15:51
I finally completed a resto mode of my Mclare MP4/4....I worked hard for a big italian modelExpo...but the date of 7 and 8 march is cancelled due to the sad problem for CoronaVirus
So i restarted the work on my GTI (and i hope to finish it this time).....i started the color change of doors. I do this as test. When all body will be ready, i'll repainted alltogheter
I finished the mod on rollcage, i check all clearance, and then I'll start the filling work on this and i'll paint in blue.
frah2o
#175 Posted : 03 March 2020 12:00:07
Yesterday in the afternoon I dedicated myself to the construction of the rest of the struts bars.
Before doing these, I coated the roof trim with thin adhesive flocking.
I’ll do the same work on front and rear pillars cover.
I then started from the simplest strut bar: the rear.
I used 2 lego brik to recreate the anchor plates and I use the 6mm plastic rod. This bar will then be used for anchoring the 5-point belts.
It was then the turn of the front bar which is just a little bit complicated.
First research was to find something for the plates to be placed on the front struts.
The diameter on the dome measures 14mm .... A pair of scooter gearbox shims help me in this work
I started working on the shims.
Both Wiechers and other brands (JOM or Bonrath) have a reinforcement on plates... I reproduced it with plastic and finally I positioned the front strut bar.
For the bar I used a plastic rod with an internal 2mm wire insert. The rod used to hardening the structure and I also used this system to bend the bar without crushing the tube.
I then applied the nut to the bar to adjust the bar tension.
I Placed the plates in position on the domes with a double-sided tape and finally I pointed the bar with a drop of cyan.
I Disassembled everything and then I finished “to weld” it with cyan and bicarbonate.
This afternoon I will go sanding, primer and painting of the whole group(rollcage and domed bars)
frah2o
#176 Posted : 04 March 2020 10:38:47
While primer coat is drying on strut bars and rollacage i moved on Seats.
I removed the black paint and i stat to flock the seat.
I use the self adhesive flocking (0.8 m) uded for jewel
Now i'have to study how to place the "Recaro" or "Corbeau" decal on headrest.
I finished the clear coat work on carbon door trim.
#177 Posted : 04 March 2020 12:29:29
Drool WOW! Just so much detail goes into your builds Love
It's what makes them stand out ThumpUp
Gray
bfam4t6
#178 Posted : 04 March 2020 17:01:53
Wow, this is an extremely impressive custom build! I’ve already done a quick skimming. Now I need to go back and thoroughly read all your posts to see if I can borrow any great techniques. Thank you for sharing, and I will continue to follow.
-Dustin
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
Currently Collecting
frah2o
#179 Posted : 05 March 2020 09:00:41
Thanks to much, and i'm happy to enjoying you with this custom build
Gray
Many thanks Gray
While i'm waiting the drying paint of rollcage and strut bars, i worked on seat brackets
I've seen many brackets (Sparco, OMP, Recaro, Rennsport and Wiechers), so i reproduced a custom bracket using Lego that for me are prefcet with size and shape
After a quick size and fit checking, i smoothed the bracket and i holed them for a futur fixing with 1.4 nut and bolt
Before to check the rollcage I removed from the rear carbon trim the central pillar cover....everything is good with good clearence
I then fitted the rear and front struts bar and i think looks is goood and enhance the general view of my little GTI
frah2o
#180 Posted : 07 March 2020 10:23:26
I finished the paint work on swat bracket: 1 primer coat, 2 matt black coat and 2 final clear matt coat
To fix the barcket on floor i use M 1,4 bolts and nuts
I use a longer rear bolt to fix the belts, but many friends tell me is good looking a dedicated bolts to fix them
I fitted a new bolt for future belts system
I made some test with 3 possible belts color: I asked to some tuning friends and model frieds. I choose finally the black belts. I think is more elegant
Guest (11)
11 Pages «<7891011>
This page was generated in 0.329 seconds.
