I bought this Pocher kit a few years back and made a start on the engine block. However due to an impending house move it was packed up and forgotten about for while. Since then many other builds have come and gone and now it is time to get this built.This will be built pretty much out the box although there will be some paint used here and there. The main block and gearbox has been assembled and the hideous Pocher grey plastic has had a coat of primer and aluminium paint applied whilst the rocker covers have had some matt black to tone them down. Al Spal attached the following image(s):
 Rank: Pro Groups: Registered
Joined: 25/02/2017 Posts: 340 Points: 1,019 Location: surrey
Impressive start Al. Will follow with interest. Andy.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,060 Points: 15,326 Location: ipswich
It's a great kit. I built it too a few years back. There's tons of scope to upgrade it and add the various missing parts.
Enjoy the build.
Roy.
Look forward to seeing how this turns out Al, will be following.....  .. Good luck with the build.... Regards Alan
Thanks gents Not taken loads of photos on this but have assembled the cockpit cell,no issues but found the seats were a bit tough to mount on the floorpan.A good bit of planning from Pocher is that they supply parts for both left or right hand drive configurations.Also added more engine parts and wiring as well as got it mounted into the rear subframe along with the exhaust assembly.Also made a start on the front sub frame and steering/suspension assembly.Finally I mounted the rear subframe to the cockpit and fitted the rear suspension rods/wishbones. Al Spal attached the following image(s):
 Looks good Al Very jealous Regards Gray
Thanks Carl/Gray. Have now got the front subframe on and the windscreen and wipers fitted. The kit also supplies wipers and blades to cater for right hand drive builds. The rear tailgate is next to be constructed before assembling the rear bumper and light unit with the spoiler and rear body parts.The inner side wings were added and the tailgate fitted before the whole assembly was added to the main chassis assembly.The quarterlight windows and trim was attached and the cooling scoops added for the last picture. Al Spal attached the following image(s):
Wow you are really moving along with this.I think Roy did a modification of this kit so you could easily lift the rear end off to show the engine?
Thanks Carl, I've had a few days off so been cramming as much modelling in as I can get  I have another Aventador in the stash which I intend to spend a bit more time on at a later date and utilise Paul Koo's dvd as well as a colour change. Al
Altering the rear to be fully removable is quite easy but it's not on the Koo DVD. My build is here somewhere (I think) If not, I'll post a separate page about 'how to do it'.
You're really moving ahead on this. Great stuff.
Roy.
Spal wrote:Thanks Carl, I've had a few days off so been cramming as much modelling in as I can get  I have another Aventador in the stash which I intend to spend a bit more time on at a later date and utilise Paul Koo's dvd as well as a colour change. Al Cool.Did you get the detail set by Tomaso ? Carl
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,866 Points: 20,915 Location: Northamptonshire, England
Very nice work Al, certainly coming along very nicely. Mark Regards Markwarren (Mark) Admin
Looking great Ken's the name modeling's the game.
Looks like another great build from you Al, all looking good..... Regards Alan
Joined: 13/02/2011 Posts: 2,239 Points: 6,837 Location: East Sussex
Looks a great kit to build Al,looking forward to the next post. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
roymattblack wrote:Altering the rear to be fully removable is quite easy but it's not on the Koo DVD. My build is here somewhere (I think) If not, I'll post a separate page about 'how to do it'.
Roy. Cheers Roy, I vaguely remember you building this way back Al
darbyvet wrote:Spal wrote:Thanks Carl, I've had a few days off so been cramming as much modelling in as I can get  I have another Aventador in the stash which I intend to spend a bit more time on at a later date and utilise Paul Koo's dvd as well as a colour change. Al Cool.Did you get the detail set by Tomaso ? Carl No i didn't, i seem to recall it was rather expensive although very nice. Al
Thanks for looking in Ken, Mark, Alan,Trev  more up soon. Al
More of this now done.Built the headlamps up, very fiddly but look great once done and fitted.Also connected the bonnet and hinges and then fitted the pe mesh to the front using the hot screwdriver to melt the locating pegs a little rather than using glue as per instructions.Having moved on to construct the doors and mirrors, the doors were then mounted onto the car in another fiddly operation which took several goes at  .The front body section was then fitted and secured from underneath. Al Spal attached the following image(s):
