The piston rods and crossheads here are the parts Steve1701 attached the following image(s):
parts assembled. Steve1701 attached the following image(s):
The rear under frame here are the parts Steve1701 attached the following image(s):
parts assembled Steve1701 attached the following image(s):
Rear end beam and plate here are the parts Steve1701 attached the following image(s):
The motion frame here are the parts Steve1701 attached the following image(s):
The equalising bars here are the parts Steve1701 attached the following image(s):
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,866 Points: 20,915 Location: Northamptonshire, England
Nice work Steve, looks an enjoyable build. Mark Regards Markwarren (Mark) Admin
thanks mark, it can be a bit fiddly if you have big hands, but getting there slowly.
The C57 is a wonderful kit and you are doing a great job. As it is pre-painted you have to be careful with the screwdrivers etc, but you`re obviously taking great care. Its a smart display piece when finished and I hope you have enjoyed the experience so far and look forward to seeing the completed build. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
thanks for the reply derek, on hold again as hex screws was not included, this is a good build though.
The leaf springs. here are the parts. Steve1701 attached the following image(s):
here are the parts assembled. Steve1701 attached the following image(s):
The second wheels. here are the parts. Steve1701 attached the following image(s):
The third wheels. here are the parts. Steve1701 attached the following image(s):
