Hello all, just got my 100 issue (Italy) and ... surprise... no wall charger included. So I'm stuck at the activation point, can't even check if batteries are ok, even more if the whole stuff is working...
In the meanwhile I get an answer about the missing charger and receive it, could somebody take a picture of his one to check the "electrical parameters" (input/output) and plug?
Maybe I have something fitting at home, at least to get to the 2" activation point...
Thanks a lot guys
Joined: 04/09/2019 Posts: 36 Points: 108 Location: Kent, Wa.
The output for the charger is: 15v 2000ma
The plug looks like the one in the picture on issue 100 magazine. It's a barrel shaped female plug.
Actually, if you charged the batteries as per the instructions, they're fully charged and will allow you to find out if everything works. Depending what batteries you bought, mine are 3000ma and the charge lasts about an hour before the red light comes on.
Shoot me a PM with your details. (Name, address, location, sub number) and I'll get you hooked up. (or try to, anyway)
 Rank: Newbie Groups: New Members, Unapproved Joined: 04/03/2022 Posts: 1 Points: 3
Hi guys I have the same problem no power supply and completed R2 can some one point me in the direction of one on Amazon so I can get him started up.
Any help would be great.
Stuart1985 wrote:Hi guys I have the same problem no power supply and completed R2 can some one point me in the direction of one on Amazon so I can get him started up.
Any help would be great. Here is a picture of the charger with the output information. Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
