4 Pages <1234>
Silent_Running Victory Build Log Options
Silent_Running
#41 Posted : 28 June 2011 23:41:18
Went shopping the other day. I shouldn't be allowed to go to a DIY store by myself... Laugh
A nice little hobby plane, its only 1 1/2 inches long. Great for getting in all those little tight spots...
A good quality saw with rasp file....
Same saw again with mitre box....yes it's big but the saw fits it lovely, and its also handy in case I do anything bigger BigGrin
My Perma-Grit sanding blocks arrived today as well....BigGrin
Silent_Running
#42 Posted : 29 June 2011 00:12:55
Sorry about the size of the pictures..I alter the size and save them 640x480 but photo bucket keeps reproducing them at this size. If anyone knows what I'm doing wrong I would love to hear it. LOL
Silent_Running
#43 Posted : 29 June 2011 00:21:30
Anyway on with the build....
This picture shows the base for Victory's launch under construction. No problems making this at all, and a few clothes pegs make all the difference. Wink
Silent_Running
#44 Posted : 29 June 2011 00:33:54
A couple of images showing the launch hull under construction...
I had only two issues, first the hull formers would not fit because the launch jig was too tight. I solved this problem by using a needle file. Did anyone else have this problem? Second, a mistake by myself during handling meant that I broke one of the ribs clean in two. Lucky for me it was a clean break and you would never know. A least I hope not? Laugh
#45 Posted : 29 June 2011 00:36:35
Great collection of tools, and a good start to the launchBigGrin
amipal
#46 Posted : 04 July 2011 00:37:07
No idea why the pics are coming out large - I use Photobucket, and just copy the IMG link to my posts, resizes fine.Confused Build coming along nicely though! BigGrin
Foz
#47 Posted : 04 July 2011 18:11:54
I know how you feel about goining to hobby stores and diy shops, i can never leave those places without spending more than i went for.
But as we need the tools it will be worth the effort and your build is commining along nicely
Silent_Running
#48 Posted : 25 August 2011 21:52:25
Hi Shipmates,
Well, its been some time since I entered anything into my build log. One reason is that I realised I was under equipped in virtually everything. The tools that I posted a picture of in my last post were part of this process, albeit just the start.
Next I had to provide myself with a good working area which at that point I didn't have. After I purchased some tools and varnish, sanding sealer and the like, I bought two desks which could be used for modelling. These also had cupboards and drawers and fitted my need perfectly. Next I needed glues and paints etc, for the Akagi which I had just subscribed to. Before this I had to keep bringing everything through into the main room when I wanted to model, and afterwards pack everything away again when I had finished which was a chore. Now of course things are very different, and I'm much happier.
Ok! On with the build!
Silent_Running
#49 Posted : 25 August 2011 21:58:56
At my last entry the build was on hold because I needed to construct a jig. Well I got the right angle brackets off e-bay and then I need a piece of wood for my jig. Pretty straightforward you might say...not so say I. This will make you laugh guys believe it or not there was a lengthy pause while I located a piece of wood (unbelievable but true). Anyway here is my jig....
Silent_Running
#50 Posted : 25 August 2011 22:07:22
Ok! Construction of the jig... I carefully measured and marked the centre line, and fitted five of the right angle brackets along it. I then put Victory on the board and fitted the other five brackets on the other side slowly getting the keel line straight along the plumb line I had marked out. BigGrin
Silent_Running
#51 Posted : 25 August 2011 22:15:00
Quote:
One things for certain i'm not making another move until I'm sure it's straight.
Well! I lived up to my pledge, not to do anything else until I made sure the keel was straight, and to make sure, I made the final critical adjustments using a self adjusting cross hair laser.
Silent_Running
#52 Posted : 25 August 2011 22:25:29
In between all this I found the time to produce my first 12 pounder, and I like the result. The only bit of bother I ran into was when I went to fit the cannon, only to find the hole had been incorrectly drilled. It was on the vertical not the horizontal. I thought now theres a problem Laugh its the wrong way up. LOL LOL
Luckily I had a spare and all was well
One thing I did notice though was its really tight when you file the last bit of the axles. I took it a bit too close and had to touch up with a bit of metal black. BigGrin
#53 Posted : 25 August 2011 22:31:44
nicely done,like the laser,mount the laser on the canon and wow we got a night scope,wouldn't nelson have loved that!
Silent_Running
#54 Posted : 25 August 2011 22:33:40
Next we have my first anchor, this isn't finished yet, as I still have to give another two coats of matt low sheen varnish, its only had one so far. I originally thought about using high gloss yacht varnish, but one coat of this was enough to convince me that it was totally not viable. The idea I had was to have certain wooden parts really highly glossed as I imagined that this would look really good. The reality was something else however, and I soon stripped it off, in favour of matt low sheen varnish.
Anyway here it is to the point I have got to....
#55 Posted : 25 August 2011 22:50:41
BigGrin Hi i bought an off cut from my local wood yard, its pine 45mm by140mm by 1450mm or 2inch by 6inch by 55 inches aprox, cost a fiver and is straight as a die
Silent_Running
#56 Posted : 25 August 2011 22:53:23
I have now started fitting the first deck. Boy, the nailing is a bit more tricky than I thought. I started off as per instructions, nailing the left hand side of the deck. I got to the end of nailing this first piece only to discover that it was squint and the other side wouldn't fit..... 'Disaster' Cursing.
How I got round this was fitting both sides in at the same time, to counter any movement that might result from me nailing. I put a single nail in the centre of each line to hold it steady while I put the rest of the nails in.
Needless to say I have learnt a lot from this little episode already, and I'm going to use the same technuiqe for the other part of the deck as well as marking out the nail holes in pencil before I start. Something I didn't do on this bit of decking Blushing
Silent_Running
#57 Posted : 25 August 2011 22:58:43
Thanks Karl! A 32 pounder with a laser range finder, Nelson would have loved it. LOL
Silent_Running
#58 Posted : 25 August 2011 23:02:43
Hi Andy, I could get wood, but the trouble was everyone wanted to charge me an arm and a leg for a small bit of MDF!!! It just makes me laugh...model delayed because of lack of wood. You couldn't make it up! LOL LOL
Silent_Running
#59 Posted : 25 August 2011 23:36:12
Ok! In my final post today I'm going to tell you what's next and what's around the corner. I'm going to carry on with the decking and I will post pictures of that tomorrow. I want get the first deck finished tonight and the ribs glued.
What's around the corner......
Well I'll be giving more detail on the other Victory hulls I've got (I mentioned these at the start), updating my log with any new developments. And also I will be introducing you to my new build helper 'Mr T'... No its not Tomick or B.A. (though I'm always grateful for help received from the holy one )! Laugh LOL
Anyway that's it for now shipmates, stay safe, thanks for looking and happy building. BigGrin
P.S: Any comments gratefully received as always.
P.P.S: More on the Akagi coming soon in my Akagi build diary! BigGrin
#60 Posted : 27 August 2011 21:59:38
Hi Glenn, great preperation -- nice Dry Dock, and fabulous build.
Keep up the good work, GOOD STUFFBigGrin Cool
4 Pages <1234>
This page was generated in 0.354 seconds.
