4 Pages <1234>
OldMart Options
OldMart
#41 Posted : 30 December 2019 12:23:01
Rank: Amateur level 2
Thanks Alan.
This may seem a silly question, however I will be planking the deck shortly and I was wondering how many planks to put on at a time? I was thinking of putting the centre plank first, then when dry one on either side, two planks at a time working out, would that be ok?
regards Martin.
#42 Posted : 30 December 2019 12:34:28
OldMart wrote:
Thanks Alan.
regards Martin.
Hi Martin, on this forum there isn't a question that is silly, we're here to help all modellers wherever possible.... Asking questions is how we all learn....Cool Cool
With planking the deck, if you are using PVA then you only need to apply a thin layer to get a good hold. Once the plank is in position you only need to leave it for around 10mins to allow the PVA to get a good grip, then you're ready to fit the next plank. If you are planking either side of the centre plank as you suggest then your waiting time for the PVA to grip should be minimal.....Cool Cool
OldMart
#43 Posted : 30 December 2019 12:44:26
Alan. Thanks very much,
Kind regards Martin.
kpnuts
#44 Posted : 31 December 2019 09:44:37
Hi Martin when I did mine I cut my planks to 70mm which gave me 7 to a length and I cut 2 lengths at a time giving me 14 planks which I glued either side of the central plank, so I stuck 14 planks at a time with each application of glue.
OldMart
#45 Posted : 31 December 2019 14:26:45
Ken. Thanks for that a good idea, I was afraid of putting too many planks on in one go in case they buckled!
Martin.
OldMart
#46 Posted : 11 January 2020 11:40:30
Hi Everybody. An update and word of warning for beginners like myself!
After a bit of a false start through on thing and another. I dove in and started to plank the decks, when I had almost finished, to my horror I realised that in my haste I had not put on the waterways.
So looking at the mess I had made, I have ordered some new planks and I will be stripping off what I have done. A lesson I have learned. "Read the instructions proper and then read them again before doing anything.
Cursing Martin.
kpnuts
#47 Posted : 11 January 2020 12:26:59
I'm sure we've all done similar things (sometimes even things which are too late to correct(yes I've been there)) I'm sure you will manage to sort it out( do you really have to remove all the planking just to put the waterways in)
OldMart
#48 Posted : 11 January 2020 13:20:32
Hi Ken. I am taking all the planking off because I couldn't find any basswood strips to match, so I have bought Lime strips! The nearest colour that I could find. but to avoid difference in matching I think it will be better to do the whole lot again. "with more care" Martin.
ps. I forgot to say that I would need to trim off all of the planks individually at the bow but not sure by how much until the waterways are in place. Martin
kpnuts
#49 Posted : 11 January 2020 18:24:36
Cornwall model boats do a whole range of wood (including basswood) I know it's a bit late now you've bought it, but mention it for future reference.
OldMart
#50 Posted : 11 January 2020 20:05:40
Thanks for that Ken.
kind regards Martin.
OldMart
#51 Posted : 25 January 2020 11:44:33
Hi Everyone. I have at last started again, I cleared all the decking that I did and started again have done the stern bulkhead and put the waterways on. I have opted to put them onto the edge of the deck and later I am going to add a piece of 2x2mm batten rounded off along both sides at deck level.Martin
OldMart attached the following image(s):
OldMart
#52 Posted : 25 January 2020 11:47:02
sorry missed the stern bulkhead out.Martin
#53 Posted : 25 January 2020 12:15:39
Very nicely done Martin.
OldMart
#54 Posted : 25 January 2020 12:38:46
Thanks Tony. I could get some decking done but will have to wait until Monday. I have invested in a guillotine for better and more precise cutting but it isn't coming till then, still I can always go digging down at the allotment and get cold and wet lol. Martin.
#55 Posted : 26 January 2020 23:47:12
Making lovely progress Martin, very well done....Cool Cool
OldMart
#56 Posted : 05 February 2020 20:44:38
Thanks' Alan, I'm hoping to finish the main deck this week, after a lot of fussing about! anyway I am getting there slowly, will post pics when done. Martin
OldMart
#57 Posted : 09 February 2020 12:00:03
Right. deck finally done hope it looks ok with you guys? I can finally get on with the hull, hope that doesn't take me as long.
OldMart
#58 Posted : 09 February 2020 12:03:49
sorry I don't know what has gone wrong with the photos? I did resize them Martin
#59 Posted : 09 February 2020 12:26:48
Your picture data is showing they are 2880 pixels width and they need to be 650 max.
OldMart
#60 Posted : 09 February 2020 12:30:05
hope this is better?
4 Pages <1234>
