80 Pages «<6768697071>»
#1361 Posted : 17 January 2020 17:50:10
birdaj2 wrote:
Really nice work Phil.
Your attention to the small details is breathtaking.
Thank you very much Tony!
#1362 Posted : 17 January 2020 17:52:48
Markwarren wrote:
Another amazing update Phil. Hope you’ve got the champagne ready for its maiden voyage.Love Drool
HahahaLOL Thank you Mark. The champers is ready and gathering dust by the day!Flapper
#1363 Posted : 23 January 2020 22:32:54
More progress on the aft torpedo compartment. I focused on adding detail to the torpedo tube, testing for fit as i went.
See attached photo of the torpedo tube completed, painted and ready for final fitting.
#1364 Posted : 23 January 2020 22:33:57
The piston I built in a previous post could now be painted.
#1365 Posted : 23 January 2020 22:34:39
Both aft torpedo tube and piston fitted in place.
#1366 Posted : 23 January 2020 22:35:42
That concludes this weeks update. More to follow next week.
Thanks for looking in, have a great weekend and happy modelling.BigGrin
#1367 Posted : 24 January 2020 14:12:23
Excellent work as usual Phil. What a difference the torpedo tube makes.Love Love Drool
#1368 Posted : 24 January 2020 14:15:04
Hi Mark, yes it certainly does, but i couldn't of fitted it until all those other pipes and valves were in as there was no room.
#1369 Posted : 24 January 2020 23:38:24
Torpedo compartment is filling up beautifully with detail and is worth all the effort you're putting into it... Looks amazing Phil....Love Love Love
#1370 Posted : 30 January 2020 09:01:01
Thank you very much Alan!
#1371 Posted : 30 January 2020 09:06:52
This week has seen me build a depth gauge / speed indicator, located next to the aft torpedo tube.
First job was to find a suitable image, which I sourced from the U995 dvd. I cropped the image in photo editor to remove all unwanted background before importing it into power-point where I could resize to the exact dimensions I was looking for.
The attached image shows the original photo, cropped, prior to resizing.
#1372 Posted : 30 January 2020 09:09:08
The next photo shows the printed image after resizing in power-point. Don't tell work I used their colour printer!!Flapper
#1373 Posted : 30 January 2020 09:10:33
I then began to make the instrument box that displays the depth and speed. The attached photo shows the front fascia being made.
#1374 Posted : 30 January 2020 09:11:43
Fascia complete along with the instrument box. Both measure 8.0mm long, 4.0mm wide and 5.0mm high.
#1375 Posted : 30 January 2020 09:14:34
I then cut out a piece of transparent plastic sheet to suit the box dimensions. I glued it to the back of the fascia and glued the paper gauges to the other side. All of this was fixed to the main body.
#1376 Posted : 30 January 2020 09:16:21
I then added a small control box to the side of the depth / speed indicator and also brackets and electrical wire.
#1377 Posted : 30 January 2020 09:17:57
From another angle.
#1378 Posted : 30 January 2020 09:19:08
Painted. I also added a small, brass plaque to the control box as well as painting it's handle in matt black.
#1379 Posted : 30 January 2020 09:20:12
From another angle.
#1380 Posted : 30 January 2020 09:21:29
Depth / speed indicator completed, painted and fitted.
This page was generated in 0.544 seconds.
