Gluing sepele strips to hull Options
Flyteach
#1 Posted : 12 January 2020 17:39:06
Rank: Beginner Level 3
As I'm getting ready to sand, putty, and then attach the sepele strips, I'm wondering if there's any advice on whether to use wood glue or something stronger? I wasn't sure how well the wood glue would adhere to the putty.
Thanks!
Flyteach
#2 Posted : 12 January 2020 18:14:14
BigGrin Hi Flyteach the glue I use is PVA White wood glue for the second planking as its easy to use and clean up Cool
Hope this helps
Martyn
#3 Posted : 12 January 2020 18:50:29
Like martyn i also use the same woidglue that i have the the base build.
Never become slilled to use contact glues so i work on the final planking in exactly the same way asi did the first panking.
Flyteach
#4 Posted : 12 January 2020 20:02:45
Thanks very much for the quick replies. My Falcon and R2D2 builds were well within my wheelhouse of 40+ years of plastic models and engineering background, but this is my first venture into wooden models. I'm having a blast and learning a LOT of new techniques.
Jim
Flyteach
#5 Posted : 02 February 2020 21:18:48
As a follow up to this my earlier question, how smooth does the first hull planking need to be? Should it be a mirror finish? Reasonable (no finger pricks when moving hand along planks?
Thanks!
#6 Posted : 02 February 2020 21:54:22
BigGrin Hi the first planking needs to be smooth without dips or high spots along the length of the hull . It doesn't need to be mirror finished in fact a slightly rough finished wood will give the second planking something to grip to. I finish mine with 200 grade sandpaper. Hope this helps
Martyn
Flyteach
#7 Posted : 04 February 2020 02:49:45
Thanks Martyn!
Flyteach
#8 Posted : 13 December 2020 15:14:42
Hi, the Constitution build went on hiatus as I started working from home (like many) and needed to keep other things in order. As I now start to refocus on working on her, I noticed that the second hull planking strips do not seem to be as long as the instructions allude. I can set up one at the bow extending to the fourth cannon and goes around the front as shown. Then I can lay 2 more along the hull they don't quite extend all the way to the aft end. It's about a half inch short. I can easily cut and glue in the small pieces needed to finish the line, but I wondered if there was something I did wrong and my model is too big? Or is this within the error bar? Generally, I've found the instructions spot on, so this seemed a bit out of character for the build.
Has anyone else had this experience? I'm having a blast building this!
Flyteach
#9 Posted : 13 December 2020 15:59:09
Hi Flyteach, BigGrin
From your description I think you cut the first plank too short.
You say you fitted it from the bow to the fourth gun port, but the official build says it should reach the "REAR" of the fourth gun port, so if I`m right then that`s why you are about half an inch short at the stern.Crying Crying
Flyteach
#10 Posted : 13 December 2020 17:57:28
Thanks for the info, but I haven't cut anything. Second strip goes from rear of fourth port to front of tenth port. From front of tenth port to rear is about a half inch short, certainly not longer for trimming that third strip.
#11 Posted : 13 December 2020 18:47:58
Ok, Confused
I`ve just looked at the download instructions:
Referring to pack 5 - page 104 - Instruction "H" it clearly shows that the second plank goes past gun post 10 (counting from the bow).
You say that your second plank stopped at the front of gun port 10.
Using the same pic from the instructions this indicates to me that the gun ports are in the wrong place. So can you confirm that the oblong hole in the centre hull plate is above gun port 6. If its not then it may be that you have that hull plate the wrong way round.
Just a thought as without a pic of your build I`m having to make assumptions/guesses.
Flyteach
#12 Posted : 13 December 2020 21:07:15
Hi Derek,
Mystery solved (kind of :)). I certainly appreciate you making me look closer. I found that the piece I was using to measure this out is not quite 250mm. How did I get that luck? I couldn't say, I know I haven't cut it and it came out of the kit, but it's been a while since I worked on it so not sure exactly which stage it was in. I'll be checking that out and when I used full length planks, it just barely, but does get to the back. Even if not, then if the pieces are slightly short, it's just a matter of cutting some small pieces to fit. I'm pretty sure it'll work out alright.
However, you made me look more closely and it appears I may have created a unique modification to my model. Looks like I got the top deck gunwales reversed as the oblong hole is much farther back than in the picture. It's much too late to correct without doing some major cutting with a saw <sigh>. But, it will take someone with a deep background (or access to these forums) to notice once it's finished.
Have a great day!
Flyteach
#13 Posted : 13 December 2020 22:23:20
Flyteach wrote:
Hi Derek,
Have a great day!
Flyteach
Hi Flyteach,
Have sent you a PM.
This page was generated in 0.125 seconds.
