eebygums' build of Hachette F-14 Tomcat Options
eebygum
#1 Posted : 17 December 2019 10:05:36
Hi
Just snaffled this off Ebay at an extremely cheap price compared to all the others for sale on there. One drawback is the instructions are in french. However,I think it would be easy to scan them as Pdf files and then get them convert with Adobe or the various websites on the internet that do it for free.
I need to sort them all into some form of order and then start scanning, hopefully it won't be too long til i can start my build diary.
terry
eebygum attached the following image(s):
sandro71
#2 Posted : 17 December 2019 12:01:49
Hi,
why do you want to scan the manuals?? If you only want to scan the build instructions, you can download all 140 issues from the German webside [which is still online].
Sandro
eebygum
#3 Posted : 17 December 2019 12:06:02
Thanks Sandro
not able to connect at the moment will keep trying though. link does not work. all the other links for other models works but not the one for the F-14.
Never mind thanks anyway
Cheers
terry
#4 Posted : 17 December 2019 17:22:03
Love Looks an interesting build you've got yourself there! I'm sure the photo's will be easy enough to follow if you can't translate. Although there's always Google translate if you're feeling adventurous Blink
Are you going to pair it with the recently released DA Mig 29 Drool
You could stage your own dogfight dio BigGrin LOL BigGrin
Definately be following this one if you do a diary Drool
Gray
schueyking
#5 Posted : 18 December 2019 21:32:50
Love Now this looks fantastic!! I would not mind picking up this complete collection myself! I need something to do over the Christmas holidays!LOL LOL Regards, Chris.ThumpUp
eebygum
#6 Posted : 19 December 2019 13:28:45
Hi Chris
You can get this on Ebay from japan but far too expensive
terry
eebygum
#7 Posted : 19 December 2019 15:14:19
starting the build
I wasn’t able to scan the instructions although file saved as a PDF it wasn’t editable. There is another build on this site by Greyhawk, and some videos on the internet but not complete builds.
Stage 1
Make a seat (weather it a bit) and glue two strips to the canopy.
Stage 2
No great drama Glue two strips to the body and fit the front of the canopy.
Stage 3
Make the second seat (weather it a bit) then fit the two seats into the shells for the pilots, and secure the front part of the canopy
Stage 4
A bit more involved with this stage fitting the LED’s for Pilot and Navigator, secure the front dome. Then fit the two pods for pilot and navigator struggled a bit with those two until I realised that by fitting the rear pod first then the front one they just slotted into place. I did not have to make any adjustments. Finally fitting the navigators’ Radar panel and cover.
#8 Posted : 19 December 2019 16:32:13
BigGrin Great start Terry Love The instrument panels look good ThumpUp
Feeling sorry for the pilot though....Laugh LOL Laugh
Gray
schueyking
#9 Posted : 20 December 2019 21:21:33
eebygum wrote:
Hi Chris
terry
Hi TerryBigGrin
I saw these...way to expensive,Crying I guess I will have to be patient and wait for something more reasonably priced!ThumpUp
Good luck with your build!BigGrin
Chris.BigGrin
eebygum
#10 Posted : 20 December 2019 23:07:09
Thanks Chris and gray for the comments
terry
schueyking
#11 Posted : 21 December 2019 13:48:41
I see that the Mig 29 is available to build......but it is just not the same! Crying
Also doesn't have the bells and whistles of the Led afterburners like the Tomcat...Huh
eebygum
#12 Posted : 01 January 2020 11:08:43
STAGE 5
Deals with the weathering of the cockpit. I didn’t do that can’t read the French instructions. The introduction of the main metal chassis.
Stage 6
Shows the component parts also testing the Navigators LED screen (Works) and also test the first motor (works) yellow tape just means I can see the motor spinning.
Stage 7
Here, the radar assembly to the fuselage and the lower intake covers are attached to the aluminium frame.
Stage 8
Install the left landing gear and attach it to the aluminium frame. Had to be careful about the length of the shaft when you attach the door. The two metal rods were tiny
Finally fix the component to the main Chassis
Stage 9
Test the motor as before fit the motor to the shroud ensuring that the wires come out of the top also make sure the door is open otherwise it will foul it, and install the left intake fan motor onto the aluminium frame
Stage 10
Test the LED light install the left aviation light red (LED) on the left fuselage, and put the fairing on the front side of the main wing. Test the LED again to make sure it still works.
That's it for now until the next time thanks for looking
#13 Posted : 01 January 2020 11:27:29
Nice update, looks like this will be some size when finished. Love
#14 Posted : 01 January 2020 23:27:25
Looking good Terry, making nice steady progress....Cool Cool
#15 Posted : 04 January 2020 18:23:50
Looking good so far Terry and certainly looks to be a good sized model with loads of nice working features!
Very well done. Cool ThumpUp
eebygum
#16 Posted : 04 January 2020 23:33:56
Thanks for looking guys, and the supportive comments really appreciated
Terry
#17 Posted : 04 January 2020 23:38:16
Looks like a very nicely detailed kit and you are doing it justice with your build diary. WTG
Cool Cool Cool
schueyking
#18 Posted : 05 January 2020 12:22:02
Hi Terry,BigGrin
Looking great!
A very clean build indeed!Drool
ChrisBigGrin
eebygum
#19 Posted : 07 January 2020 14:26:29
Hi all
Another update stage s 11-20
STAGE 11-20
Stage 11
This is the same as stage 8. Install the left landing gear doors and attach them to the aluminium frame. Had to be careful about the length of the shaft when you attach the door. Used the short one for the front door and the larger on the rear one. The two metal rods were tiny
Stage 12
Here we get another motor cover re-fuelling pipe and a fan and the other motor from a previous issue.
Fit the inner bracket for the fuel pipe the fit the pipe to the cover.
Test the motor as before fit the motor to the shroud ensuring that the wires come out of the top also make sure the door is open otherwise it will foul it, and install the left intake fan motor onto the aluminium frame.
Stage 13
Test the LED light install the Right aviation light Blue (LED) on the left fuselage, and put the fairing on the front side of the main wing. Test the LED again to make sure it still works.
Stage 14 & Stage 15
Nothing to do on this just the issue of one of the wings
Stage 16
We will use the parts issued in 14 & 15 with the parts issued in stage 16 to form one of the wings, just a tiny drop of glue is used to secure the two wing flaps together then screw on the retaining bracket with the tiniest of screws. That completes this Stage.
Stage 17
In Stage 17, the wing tip LED cover and the wing tip lamp are incorporated into the left main wing part which was assembled in Stage 16.
Stage 18,19,20 and part of 16 Make up the wing
Stage 19 Add the small flaps to the wing part 18
Stage 20
Take off the cover for the rack then fit the cable to the board (stage 20)
Turn the board over and secure the cables with Sellotape or masking tape
Fit the board to the wing using the screws provided.
Replace the cover for the rack.
Fit the pinion to the motor and place it in the bracket on the wing fit the power cable to the board.
Then connect the wing tip cable to the board
There is no way to test the functioning of the lights and the rack and pinion for the main flap
Next fit the part from stage 16 to the wing then fit the two parts of the wing together with a push fit
That is the first Wing completed
eebygum
#20 Posted : 08 January 2020 12:11:36
Hi All
Another update for this build
STAGE 21-27
Stage 21 to 27 is the build of the second wing. The instructions and parts are the same, so not much point in taking 20-30 pictures, we end up with 2 wings complete
Stage 28
We are supplied the wheels and tyre for one landing gear
Stage 29
Build the landing gear
Split the main gear leg to insert the cog and spindle ensuring that the slot in the gear fits onto the protrusion on the landing gear leg. Join the two parts back together and assemble and fix the wheel
Stage 30
The left main landing gear is completed by combining the parts assembled in No. 29 with the parts that come with stage 30
This page was generated in 0.507 seconds.
