51 Pages «<4647484950>»
DaDokta`s Build Options
z8000783
#941 Posted : 10 December 2019 13:17:53
Groups: Unapproved
Looking gorgeous, Walter.
gingerale75
#942 Posted : 10 December 2019 14:12:54
Looks fantastic Walter, almost finished.
Regarding the flags, I have no real suggestion, but I know that the supplied flags are too stiff to make it hanging loose (simulate no wind blow).
As I fitted the sails I tried to simulate wind blow by keep curling it left/right (wave form) when sticked the two halves together gradually...
If you want hanging them loose then I suggest get replacement flags from soft material.
I hope it helps.
Happy building!
Laszlo
#943 Posted : 10 December 2019 14:14:45
Thanks John, and thanks for your suggestion Laszlo!
#944 Posted : 10 December 2019 15:32:12
Hi Walter,
This build has turned out to be a masterpiece, Walter your work has shown your skills at a very high level.
Trev.
#945 Posted : 10 December 2019 17:35:30
Impressive work on your rigging and very quickly completed.
All looks really good.
While its not a technique i have tried i did read an article were someone had sandwiched some thin metal (ie tin foil) between the flag halves.
So when its folded you have an inner core that will hold its shape.
#946 Posted : 11 December 2019 00:41:12
A truly first class build Walter. The many hours of patience and skill you've applied throughout the build has resulted in a build you should feel exceptionally proud of... Credit to you and very well done indeed....Love Love Love
#947 Posted : 11 December 2019 09:40:06
Thanks Trev, Tony and Alan!
#948 Posted : 17 December 2019 10:28:16
I´ve been working on the first anchor lately.
I simulated the iron bands with 2mm masking tape.
Used a much bigger brass ring than the one provided - the seizings are not perfect - but this was my first try.
#949 Posted : 17 December 2019 16:55:12
Its all looking good Walter.
Interesting seeing this part of your build as it takes me back a good number of years when modelspace forum was running the victory build for the first time.
There were lots of people following along at the time and i remember the discussions and debates going on regarding making the anchor more accurate (as you have done here).
It was great being part of the "radical thinking" making changes to the model and i must admit at the time i felt really good being guided by some of the long gone experts we had on this channel at that time.
I think at that time ship building partworks while not totally new, had never really been supported with a build forum (or at keast a decent one) and the interest and enthusiasm from Victory builders was really good. I think everyone was trying to learn as much as they could so they could turn out a decent ship at the end.
Your anchor build looks spot on.
Kind regards
#950 Posted : 18 December 2019 10:38:31
Thanks Tony!
#951 Posted : 18 December 2019 11:06:52
Nicely done Walter, good tip using the 2mm masking, works very nicely.....Cool Cool
#952 Posted : 30 December 2019 13:45:00
Thanks Alan!
This is a small update. Anchors are all prepared and one of them fitted to the ship.
FightingWillie
#953 Posted : 31 December 2019 01:05:16
Rank: Amateur Level 1
That is some beautiful work
#954 Posted : 01 January 2020 17:18:14
Hi Walter,
Good to see you back.
I've also been off the radar for some time now.
Once again superb updates Love
I agree with you about the flags. Alan & Martyn gave me this advice...
http://forum.model-space...sts&t=6314&p=27
I used their method and was happy with the results. One thing I can suggest though, if you are going in this direction, it to try getting an extra set of flags & do a test first. It just doesn't feel right while you're doing it & it's very messy.
Hope this helps.
#955 Posted : 01 January 2020 20:07:39
Thanks for your advice, Garth!
#956 Posted : 02 January 2020 12:39:17
Nice work on the anchors.
Still amazes me just how large these are in real life and to think victory had 4 of them.
#957 Posted : 16 January 2020 13:59:09
Thanks Tony!
The anchors are attached. On starboard i only rigged one anchor as i plan to Display one of the anchors aside the ship.
#958 Posted : 16 January 2020 14:38:40
Beautifully done Walter, a true work of art from the outset.....Love Love Love
#959 Posted : 16 January 2020 20:46:41
That is a stunning build.
Its so detailed a model iand in the hands of a skilled builder such as your good self it turns into a very beautiful model.
goddo
#960 Posted : 17 January 2020 11:21:21
Walter, you are doing a brilliant job of this model.
I love reading your diary and it gives inspiration to all of us, I imagine.
CHRIS
