13 Pages «<34567>»
Micks 1/200 battleship bismarck Options
#81 Posted : 08 December 2019 21:38:10
BigGrin All looking good and nice work Mick Cool
#82 Posted : 08 December 2019 23:55:56
Great work Mick, coming together very nicely.Love Love Drool
#83 Posted : 09 December 2019 01:08:22
Lovely work Mick, coming along beautifully....Cool Cool
#84 Posted : 01 February 2020 17:59:25
Hi thanks to all who looked in and left comments, after bit of delay in delivery's why hachette move there warehouse, got few more issues
Issue 39
This just another hull plate with the black and white stripe, just screw it in same as previous plates.BigGrin
#85 Posted : 01 February 2020 18:21:51
Issue 40
First of all fix the label to the searchlight led cable,then thread the searchlight Base onto cable making sure it's the right way round, fit the searchlight lens into the body,fit the led into the searchlight back,again make sure it's in the rail get way up.then glue the back onto the body,clip on the searchlight support, then attach the arm and glue this to the support, then slide up the Base and glue this to the bottom, then thread the wire through the searchlight Base deck, glue the deck to the platform, then glue on the searchlight, then add locker structure to the deck behind the searchlight. Next glue together the 2 half's of the upper superstructure, glue a ladder to one side of this. Then glue the searchlight platform to the upper superstructure. Then retrieve the radar assembly from previous issue and glue on the few bits of etch to this,and finally glue on the 4 zag artillery guidance devices making sure they facing the right way.cheers mick. BigGrin
#86 Posted : 01 February 2020 18:27:23
Issue 41
Just the same as issue 39 but attach hull plate to other side. BigGrin
#87 Posted : 01 February 2020 18:30:28
Issue 42
Again just another hull plate to start extending the next section of Hull, that's it for now. Cheers mick. BigGrin
#88 Posted : 01 February 2020 23:46:31
Lovely update Mick, she's coming along beautifully.....Drool Drool
#89 Posted : 16 February 2020 13:11:19
Hi thanks to all who looked in and left comments much appreciated.
Issue 43
First of all fit the 2 small gratings on to the 2 larger ones then glue these to the side of the admirals bridge deck.attach the sticker to the light bulb cable,then fit the bulb into the windows,then assemble the 2 sides and front to the window,then hold all in place with the deck on top of it.then bend the 3 bits of railing and glue these to the deck.then glue this assembly to the deck,then glue on the searchlight assembly from previous issue to this.then glue the 2 shelters to the deck at the rear.cheers mick. BigGrin
#90 Posted : 16 February 2020 13:28:21
Issue 44
First of all glue the deck onto the upper mast deck.and glue the 2 half's of the conning tower together.then glue the conning tower to the deck.paying attention to which way round it goes it has 2 holes in one side which need to be on the right hand side.then glue the 5 bits of etch together that make up the ammunition hoist,then glue this to the deck at the front.then glue in 3 lockers around the conning tower,I had to cut bit off bottom of tabs for these to get them to sit on deck flush.then a further part is glued in those 2 holes mentioned before. Then glue in the 2 bits of preshaped handrail.we also get 2 replacement anchor rings, I not put mine on yet as I'll have to remove anchors to paint the red portion of deck. Cheers mick. BigGrin
#91 Posted : 16 February 2020 13:45:40
Issue 45
First of all glue the 2 rangefinders onto the admirals bridge deck, then glue in 2 signal lamps.then glue in 2 loudspeakers one each side.then bend 2 bits of handrail and glue on the grated portion of deck. Then there's 2 bits of preshaped handrail. To go on the small platforms where the rangefinders are, mine just needed small squeeze in to fit properly.then there 2 platforms to bend and fit under the admirals bridge deck. Then glue in the angled ladders one each side.then there are 3 antenna supports to glue on. Then glue the admirals bridge deck assembly to the upper mast assembly,I had to trim the rear tabs to get this to seat properly. And just put the tops of the angled steps into holes of deck above them.BigGrin
#92 Posted : 16 February 2020 13:50:21
Issue 46
After the previous 3 fiddly issues it's nice to have a simple one
Just another hull plate to fit,then final pic of what we have so far. Till next time cheers mick. BigGrin
#93 Posted : 16 February 2020 13:55:10
Nice work Mick, you seem to have a knack with these battleship models! Well done. Cool
#94 Posted : 08 March 2020 13:55:47
Hi thanks to all who looked in and left comments much appreciated, on we go.
Issue 47
First of all we attach 2 more the yellow liferafts, then glue in 4compass 2 on the admirals bridge and 2 on the foretop gallery, then it's bend 2 more bits of handrail one fixed to each of the fore mentioned assemblys, then there are 3 circular rails to glue to the conning tower.then 2 more bits of handrail are glued onto the admirals bridge. Then we fit the foretop gallery to the admirals bridge. Then it's make up to ladders, now here is an error to say the least in the instructions, they built them the wrong way round ie the back of the ladders face the front,I just turned mine around so the steps looked right unfortunately this puts the location pins on top of the ladders instead of at the bottom where they should be, so I cut these off, anyway looks better this way, even though they end up not locating in the holes in decks anymore.hopefulpy if any more ladders they get them the right way round from now on.Then there are 3pipes to be fitted to the rear of forward superstructure. Cheers mick. BigGrin
#95 Posted : 08 March 2020 14:00:59
Hi forgot to upload pic of 3 rails on conning tower.cheers mick.
#96 Posted : 08 March 2020 14:04:15
Issue 48
Here we just get another bit of deck,just simply screw to previous deck,cheers mick. BigGrin
#97 Posted : 08 March 2020 14:09:01
Issue 49
Here just another hull plate to screw on. Cheers mick. BigGrin
#98 Posted : 08 March 2020 14:23:22
Issue 50
Another one that will test your modelling skills to the limit,stick a label on the motor cable.cheers mick. BigGrin
#99 Posted : 08 March 2020 15:34:09
BigGrin Coming together nicely Mick. Your really cracking on with this one ThumpUp
#100 Posted : 09 March 2020 00:00:22
Beautiful work Mick, really coming along very nicely indeed.....Drool Drool … Especially love your label attaching skills.....LOL LOL LOL
13 Pages «<34567>»
This page was generated in 0.696 seconds.
