Zuy9o Options
Zuy9o
#1 Posted : 06 December 2019 14:05:16
There was a problem ! Scroll mechanism when opening and closing the manipulator ! And the bottom somehow twitches at the same time all and when you open it comes to the stop and begins to scroll and when you close the same ! ???
Tell ME what to do what is the problem ? Opens all the way and closes then starts to scroll !
#2 Posted : 07 December 2019 09:39:08
Your mechanism for the arms don’t look right, here is a picture of mine for reference.
Zuy9o
#3 Posted : 30 December 2019 11:02:36
It doesn't read the code so I can't connect to Wi Fi? What to do?
20 minutes of sitting , even the lens removed ! But on direct connects video shooting and photo goes! So the camera works... Confused Confused
skyfire
#4 Posted : 30 December 2019 12:02:11
Publisher Medal: Featured Build of the MonthActive Service Medal: 500 post active service MedalBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
What have you tried to get it to read the code ??
As in changing light conditions and moving the code closer or further away from the lens ?
Also have you tried looking at the R2D2 troubleshooting guide ?
https://forum.model-spac...aspx?g=posts&t=32756
Zuy9o
#5 Posted : 30 December 2019 17:05:23
Yes, moving away and approaching ! no result . And not only I have in group already man 6 wrote about this . Indeed there is no here on forum !
skyfire
#6 Posted : 31 December 2019 11:40:07
A thread where someone had a similar problem and they ended up getting in touch with C/S for a new pcb card.
https://forum.model-spac...aspx?g=posts&t=32738
This page was generated in 0.225 seconds.
