80 Pages «<6465666768>»
#1301 Posted : 30 November 2019 09:18:04
BigGrin All looking good and nice work Phil Cool
#1302 Posted : 01 December 2019 06:59:02
Brillisnt work Phil.
I had been so taken with the outside parts of your build i had forgotten this thing has internal features.
Some really neat scratch building you are doing and impressive.
#1303 Posted : 12 December 2019 20:03:51
Thank you Andy!BigGrin
#1304 Posted : 12 December 2019 20:04:58
Thank you very much Tony!Cool
#1305 Posted : 12 December 2019 20:14:25
BigGrin Impressive stuff, as always Phil ThumpUp
#1306 Posted : 12 December 2019 20:18:30
Well it's been a couple of weeks since my last update. Last week I decided to have a few evenings off from modelling and this week has been spent doing research. I'm currently in the process of fitting out the aft torpedo compartment with it's myriad of pipes and valves. I won't be able to replicate all the plumbing as this build would take 20 yearsLOL, so it was a case of working out what to make and what to leave out. This was how i spent Monday and Tuesday evening. Wednesday i made a start, concentrating on the larger pipes first. Using 2.0mm diameter round acetal rod, i soon found out that it doesn't like bending around corners, even when dipped in boiling water. I then tried 2.0mm diameter brass rod and found this metal too hard to work. I then realised the best material to use is solder; flexible, easily bent, doesn't snap and will take paint. So after a couple of hours trial and error last night and getting nowhere fast with the plastic and brass, i ordered a reel of 2.0mm diameter solder today.
Consequently, I haven't made lot of practical progress this week, which is always the case when conducting research. Although i did make two housings for this pipework to fit into on the top and side of the torpedo tube as seen in the attached photo.
#1307 Posted : 12 December 2019 20:31:44
The attached photo shows the aft torpedo compartment of U995 and all of it's pipework!
#1308 Posted : 12 December 2019 20:34:03
That concludes the update for this week and hopefully a bit more progress will follow next week.
Thanks for looking in and your comments, have a great weekend and happy modelling!
Phil W.BigGrin
#1309 Posted : 12 December 2019 21:44:47
Thank you very much Gray!BigGrin
#1310 Posted : 12 December 2019 22:28:17
Nice work Phil Love Drool Drool , see you are going have your work cut out.Cool
#1311 Posted : 12 December 2019 22:36:51
You may not be able to fit all the pipework and plumbing Phil but am sure what you do fit will look absolutely amazing, look forward to see it all come together.....Cool Cool Cool Cool
#1312 Posted : 13 December 2019 17:09:09
Thank you Mark. Yes mate, it will take a little time. The trickiest part is formulating a working method and technique that is repeatable. Once I have that solved I can apply that to all the pipework that I make and not spend longer than required to get the job done.
#1313 Posted : 13 December 2019 17:12:16
Thank you very much Alan! I'm hoping to convey the sense of complexity without replicating everything verbatim. I mentioned to Mark, it's about solving the technique and working method to be able to repeat consistently.
#1314 Posted : 19 December 2019 22:37:37
A little more progress this week making pipework. Lots more to do but it's a start.
The attached photo one of the largest diameter pipes made using 2.0mm solder and M2 washers as flanges. I made the valve body from plastic strip and drilled a 0.8mm diameter hole in the top to accept a piece of bent brass to represent the valve handle.
#1315 Posted : 19 December 2019 22:38:49
Painted.
#1316 Posted : 19 December 2019 22:39:23
Fitted.
#1317 Posted : 19 December 2019 22:40:30
I then made a smaller diameter pipe using 1.2mm diameter solder. This section has two valves and was a tad tricky to fit.
#1318 Posted : 19 December 2019 22:41:29
Painted.
#1319 Posted : 19 December 2019 22:41:56
Fitted.
#1320 Posted : 19 December 2019 22:48:09
I also applied a black wash, but looking at the photos it requires toning down a bit; nothing a cotton bud dipped in thinners can't sort.
Well that's the update complete for this week. With the holidays soon upon us, my next update will be at some point in the next week and a half [ish]!Flapper LOL
On that note i would like to wish everyone a very Merry Christmas!
Phil W.BigGrin
This page was generated in 0.694 seconds.
