10 Pages «<678910>
Ant62 victory build Options
Ant62
#141 Posted : 22 November 2019 20:55:30
Some of you may know of the incident with our puppy getting his gnashers into the victories bow and caused some damage..
Well on thursday and today (friday) ive managed to remove most of the damaged planks from the bow and the sides.
The bow ribs/supporters looks quite a simple repair so far.......
A bit of strengthening and im hoping i can continue the build.....
Hopefully my phone arrives on saturday then i can add some pictures.....
Building.
HMS Victory.....
Corel Albatross 1840......Completed
Hindenberg Zepplin museum piece..Completed
Artesian Latina Sopwith Camel.....Completed
Bismark.........
#142 Posted : 22 November 2019 23:29:56
Well done Ant62 that takes skill to repair aa job like that, it is something you have to do and figure out for yourself.
Trev
Ant62
#143 Posted : 05 December 2019 11:05:53
I have moved the repair build back onto my build topic where i really should have put it in the first place.....
As i said on the other topic the replanking of the bow just didnt line up with the planking on the sides on width..
Even though i put the same amount of lengths and butt joined them after a couple of planks placed the butted planks became smaller when next to each other...
So after a while and carefull thought i decided to remove the planks from bow to stern covering the lower cannon ports on both sides.
This will give me a straight edge to work back down the hull.
It does not matter if it adds more time to the build but to me it had to be done and it gave me peace of mind...
Once removed(pics below) i then found some damage from the dropping incident.
Because i could not remove and bulk frames i used the ones the Delboy sent me.
I cut them to size and glued and clamped the into position this will strength the the cracked bulkheads luckily i could not see any damage further up the ribs as they get thinner and shaped so thats a plus...
I have a few bits of planking to remove from stern/transend and then im onto carefully removing the dried glue....
Ant62 attached the following image(s):
Building.
HMS Victory.....
Bismark.........
#144 Posted : 05 December 2019 11:40:46
i think this was a good decision and wish you the best of luck with the repair!
Ant62
#145 Posted : 05 December 2019 12:00:54
Thanks.......BigGrin
Building.
HMS Victory.....
Bismark.........
#146 Posted : 05 December 2019 12:20:41
Its a shame you are having to remove so much but at least when its all back together you will know that its all sound snd will have confidence the rest of the assemble will build on afirm base.
Ant62
#147 Posted : 05 December 2019 14:21:34
Well tbh removing the glue didnt take long only a couple of hours.
While im at it i gave the gun ports a fresh lick of paint aswell..
What i have noticed in the rebuild is that the timber supplied in the first few boxes with the with the monthly subscription is rather brittle.
Then the continuing boxes had timber the was very hard to bend know matter how long i soaked it for so ended up buying new limewood strips......
Building.
HMS Victory.....
Bismark.........
Ant62
#148 Posted : 06 December 2019 11:37:28
Started to evenly lay the planks yesterday on both sides.
I only pinned down two rows just to gauge how the lie on the ribs and around the bow.....
Building.
HMS Victory.....
Bismark.........
Ant62
#149 Posted : 06 December 2019 20:54:12
So the big refit(BigGrin) is moving along nicely.
I had plenty of free time the last few days..
One thing i have found out is after i pulled the planks off etc there where bits to do like faring etc.
The picture shows one side but ive evenly planked both sides....
Building.
HMS Victory.....
Bismark.........
Ant62
#150 Posted : 07 December 2019 14:08:49
Madam is stuck in accident traffic so i decided to to a bit....
Building.
HMS Victory.....
Bismark.........
#151 Posted : 07 December 2019 14:30:23
And very neatly done.
Hope it continues well.
#152 Posted : 07 December 2019 22:01:08
well done Ant looking good
Trev
gingerale75
#153 Posted : 07 December 2019 22:52:34
Well done for the repair/rebuild activity, I'm sure it will end up OK.
Happy building!
Laszlo
Ant62
#154 Posted : 08 December 2019 20:16:07
Thanks all...
Hopefully by the end of the week im almost back to where i was until the pup got involved..
So basically i will onto cutting out the ports....
As you can see ive a few bow planks to bend and fit also the stern to finish then the ports to cut out..
Building.
HMS Victory.....
Bismark.........
#155 Posted : 09 December 2019 16:25:12
Really good to see this one well on the road to recovery. BigGrin
WTG Cool Cool Cool
Ant62
#156 Posted : 11 December 2019 14:01:15
A little progress report...
The transom and the sides are replanked now.
Just the bow to plank.....
The three planks going around the bow with the gaps are just tacked into place as i made the same for each side.....
Its a case of soak several planks bend with the iron then attach one on each side leave to dry then attach 2 more the day after...
Glue them in the morning then a few hrs later bend 2 more and pin then leave to dry......
Building.
HMS Victory.....
Bismark.........
#157 Posted : 11 December 2019 19:09:52
That looks really good.
Still some way to go on my own victory but i restarted it and its amazing just how the issues you may have encountered the first time around suddenly vanish.
The only task i dont envy you is having to re-cut all those gun ports but sure you will get through all of that very well.
Ant62
#158 Posted : 11 December 2019 19:47:22
That is something im not looking forward to tbh.
The limewood im using seems to be a bit harder than the first lot supplied with the suscription.
But its another step forward in the rebuild........
Building.
HMS Victory.....
Bismark.........
Ant62
#159 Posted : 14 December 2019 10:31:46
Well im now onto marking out the middle and lower gun ports later today....
Once i have marked out the gun ports thats me done for a few days just happy to be at the point of a repaired ship...
Just noticed that my supply of limewood as a reddish tinge to it and not the usual plain white....
Photos later
Building.
HMS Victory.....
Bismark.........
Ant62
#160 Posted : 15 December 2019 16:29:12
The two pictures show where im upto.....
Im giving it a rest for a bit now......
Building.
HMS Victory.....
Bismark.........
Guest (6)
10 Pages «<678910>
This page was generated in 0.309 seconds.
